solid or polyurethane motor mounts
Old Apr 6, 2009 | 08:14 PM
pauls99z28's Avatar
Default solid or polyurethane motor mounts
I need some of your opinions. Im planning on changing my motor mounts on my Z. What are the pros and cons of a solid compared to a urethane? My car is 400hp @ the wheels with a pretty big lift cam.
Old Apr 6, 2009 | 08:29 PM
01ssreda4's Avatar
do a search.... i personally went with polys and love them.
Old Apr 6, 2009 | 08:30 PM
pauls99z28's Avatar
So you can actually tell the difference from the stock mounts?
Old Apr 6, 2009 | 09:30 PM
Siphon's Avatar
Here are a couple of threads on the solid mounts. The first one is my experience with them, with a mildy modded LS1. The 2nd is from a guy with a big cam.
https://ls1tech.com/forums/generatio...e-updated.html
https://ls1tech.com/forums/generatio...or-mounts.html
Old Apr 6, 2009 | 09:32 PM
Siphon's Avatar
and yes, you can tell a difference.
Old Apr 6, 2009 | 09:33 PM
TheSilverOne's Avatar
you can't go wrong either way
Old Apr 6, 2009 | 09:37 PM
Siphon's Avatar
seems like we jump all over these solid mount debate threads lol. I will always defend them, now that I have some. There are a lot of myths going around about solids. Its time that they get cleared up.
Old Apr 6, 2009 | 09:40 PM
Steve Gunn's Avatar
I went with poly motor and rubber trans because I want to keep my fillings in my teeth!
Old Apr 6, 2009 | 09:42 PM
Minshall's Avatar
I have solid in my car and i love them. I figured my car would rattle like crazy, but it doesnt. But like everyone says, either way is better than stock.
Siphon's Avatar
Did your current car have solids motor mounts beforehand, or are you just assuming that the vibrations would be unbearable?
Old Apr 6, 2009 | 10:06 PM
98RedBird's Avatar
Solid... They are NOT unbearable... the ones who say they are more than likely haven't had them...
And if they have had solid mounts and they call it unbearable they're a *****. Plain and simple.
Old Apr 6, 2009 | 10:13 PM
Siphon's Avatar
This is 100% true.
Old Apr 6, 2009 | 10:18 PM
pauls99z28's Avatar
Thanks guys for all the feedback. Im goin with the solids .
Old Apr 7, 2009 | 12:25 AM
Captain InsaneO's Avatar
Solid motor mounts makes it a complete pain in the *** to remove the transmission if that need ever arrives. I know first hand.
Old Apr 7, 2009 | 01:54 AM
98RedBird's Avatar
This is also 100% true. I know first hand as well.
Old Apr 7, 2009 | 10:59 AM
Siphon's Avatar
This guy is telling the 100% truth yet again. If you plan on doing any tranny mods, you might want to do them first. I made the mistake of putting in the mounts BEFORE my TC. I regret that now.
Old Apr 7, 2009 | 07:07 PM
slayerized6's Avatar
i got poly mounts here. if you sat in my car, you would think i have stock rubber mounts. no extra vibration with polys
Old Apr 7, 2009 | 07:45 PM
Wesmanw02's Avatar
Go with poly unless its an all out track car.
I have polys in mine, you get 95% of the stiffness of solids without the harsh vibrations. There really are no downsides to poly mounts, solids are overkill for a 400WHP street driven vehicle.
Old Apr 7, 2009 | 08:06 PM
pauls99z28's Avatar
Thanks for the info. I almost went with the solids but am now gonna go with the polys.
Old Apr 7, 2009 | 09:37 PM
Johnnystock's Avatar
My polys are doing very well and are waayyyyyyy better than stock!! No vibration and holding fine with N2O..
