ls2 vs. fast.
Old Apr 8, 2009 | 12:13 PM
bifster's Avatar
Default ls2 vs. fast.
I currently have an LS6 intake is there any benefit to going to the ls2 intake other than the bigger 90mm tb? Is there a huge difference for the 800 dollar difference between the fast and the ls2?
Old Apr 8, 2009 | 03:10 PM
c0ncEpT's Avatar
You cannot run an LS2 intake on an LS1. Thats the difference
Old Apr 8, 2009 | 03:35 PM
bifster's Avatar
with the addition of ls2 heads you can... correct?
and if ls2 heads are the same as ls6 heads whats the difference
Old Apr 8, 2009 | 06:27 PM
SweetS10V8's Avatar
100% incorrect. You can run an LS2 intake on an LS1, you just need a 90mm throttle body.
Anyways the LS2 is a downgrade from your LS6, The FAST would be an upgrade. Your in the middle right now.
Yes!!
Old Apr 8, 2009 | 08:30 PM
c0ncEpT's Avatar
Yeah my bad I was thinking LS7 intake for some reason.
Old Apr 8, 2009 | 08:32 PM
Johnnystock's Avatar
Yes!!
100% correct
Old Apr 8, 2009 | 08:34 PM
you need injectors adapters to run the LS2 and a ported version of the LS2 could be superior to the LS6 but not many proof lying around. The best thing that could happened to us LS1 guys is a 92mm LS6...wont happen
Old Apr 8, 2009 | 09:37 PM
massls1guy's Avatar
The OP has an LS1 engine from a 2002 Z28. He says the engine has no mods. The fast intake won't give you a good gain. Don't put on a fast until you at least have all the bolt on mods and a cam.
And FYI, Sweet's dyno graph is a 6.0 LS engine, not a 5.7 like the LS1. His dyno graph is comparing the LS2 and the fast. So you probably won't see gains like his if you swap your LS6 for a fast, especially with your current mods.
Old Apr 8, 2009 | 10:21 PM
SweetS10V8's Avatar
I think I personally went over that when I explained to him.
Then I specifically re-quoted, just so there was no confusion, "Is the FAST worth $800 over the LS2 intake." And I posted a dyno of an LS2 intake vs a FAST intake. Thats what he asked for!
Power gains are relative too, you seem to imagine there is a huge difference between a 5.7L and 6.0L. Its not really that different. If a 6.0L picks up 21hp, a 5.7 would most likely gain 17hp (ish).
I post to help people with their questions, even if they are the samequestions...over..and over...and over again. And everytime its a FAST LSX related question I always wonder how long it will be until you see it and again try to discredit good data.
Old Apr 8, 2009 | 10:46 PM
massls1guy's Avatar
I disagree about that gain on a stock LS1. And you're missing the point. Your engine is different than these LS1 guys in several ways:
- displacement (as you said)
- stock intake manifold
- cylinder heads (241 vs LQ9 -> 243 ports with a bigger chamber)
So it's not really comparing apples to apples.
And bolting a fast intake onto a stock 2002 LS1 doesn't give much gain at all.
You present the data as if it is relevant to the LS1. I don't think it is.
If someone asks if bolting a fast onto a stock LQ9 will give a good gain you have the perfect data for them.
Old Apr 9, 2009 | 08:51 AM
teke184's Avatar
got a dyno graph go show it?
track times?
while i don't think there are huge gains to be had, i think it will still make power.
and whether its worth the added cost is TOTALLY up to the buyer.
if he's planning cam or h/c down the road, and wants to tinker with the engine as it is now...why not get the fast.
i say do it....and post dyno results
Old Apr 9, 2009 | 10:30 AM
massls1guy's Avatar
track times?
No, no.
But from reading a lot of posts I think the gains will be pretty small.
As you know the 2002 has an LS6 intake from the factory. The fast will probably gain a few HP in the upper RPM, might lose a few at other RPM.
I agree completely.
What mods to get is a personal choice of course, different for everyone. Getting a fast as the 1st mod on a stock LS1 engine isn't a great choice if you want to see gains before you upgrade H/C. If anyone just wants to tinker or even just likes the look of it that's cool, get the fast.
To the OP I say don't do it until you have all the bolt on's and a cam and/or heads.
Old Apr 9, 2009 | 08:58 PM
bifster's Avatar
wow yah ok guys haha didnt want to start a fight!! thanks for the input i do understand 317 heads are identical to 243's with added chamber volume thats is the reason i have a set for my ls1. anyways thanks for the info basically i wont bother getting an intake till its actually my limiting problem as i know the ls6 intake is a well manufactured piece. thanks again!
