cutout hp
Old Oct 30, 2003 | 09:01 PM
mattsls1's Avatar
Default cutout hp
how much hp will a cutout give me. i dont have headers or anything. will it sound good. thanks in advance.
Old Oct 30, 2003 | 09:21 PM
jimmyblue's Avatar
Moderator
I ran a guy who had a cutout once and it sounded
pretty bad-***.
How much gain depends on what kind of exhaust you
have on there. If you figure the SS exhausts were
(rated to be) good for 10HP over stock and that
was still with a muffler, you can figure a cutout is
good for at least a little more than that.
Old Oct 30, 2003 | 09:25 PM
mattsls1's Avatar
whats the best made manual cut out. thanks
Old Oct 30, 2003 | 11:23 PM
Jeffs99SS's Avatar
I have a 3" Summit cutout (I'm pretty sure it's made by flowtech). Sounds absolutely badass under WOT acceleration. Part throttle or cruising doesn't sound that great, but hey, it was only like $25. Not sure about HP. If I were to guess, maybe 5 horse over SS exhaust, 10 over stock??? It's a good mod IMHO, since you can easily make it quiet if you need/want to.
Jeff
Old Oct 31, 2003 | 02:47 AM
Jabroni's Avatar
FWIW, I gained 17 RWHP opening mine. Not a bad mod for cheap power!
Old Oct 31, 2003 | 08:08 AM
Brandon_TA's Avatar
Definately get a cut-out... got mine from Jegs, and you can damn sure tell that there is more power there, even if just a little. Sounds damn good too... IMO
Old Oct 31, 2003 | 08:16 AM
next's Avatar
I have the SLP dual/dual exhaust and a cut-out and have done testing on the dyno with it opened/closed. When the car was near stock it netted 10hp. Now with H/C, headers etc., my gains are 22hp.
Old Oct 31, 2003 | 10:28 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I gained 20 dyno proven hp.
 Michael S. Palmer
Old Nov 4, 2003 | 12:55 AM
TNormZ28's Avatar
I did back to back runs at the track 1 open cutout run 1 closed cutout run. The open cutout dropped e/t by just shy of 3 tenths by slightly increasing my trap speed. Best bang for the buck out there. Everything else in the run was identical. This is an A4 car. Try the sponser Speed Inc. to the right.
Old Nov 4, 2003 | 01:22 AM
Cal's Avatar
Cal
Hmmm interesting thread . . . proves most fbody exhaust systems are still pretty restrictive, especially for a modified engine; I suspected that.
Old Nov 4, 2003 | 02:43 AM
Joker # 9's Avatar
I threw down 320hp and 340tq with just a 3" cut out added to my 01 SS M6. Although I have seen others dyno higher stock I am still happy with it. Definatly sounds good at WOT!
Old Nov 4, 2003 | 01:53 PM
mike c.'s Avatar
ss421- how did you gain 3 tents from a cutout? i have a head and camed car,ect,ect and i gained NOTHING AT ALL at the track.i have the q-tec elect cutout. i made 6 runs open and 6 runs closed and nothing but noise.
Old Nov 4, 2003 | 02:19 PM
BuckeyeROC's Avatar
King of Pigskin Knowledge
I went from 12.39 @ 109.5 to 12.17@111.93 MPH with nothing different except a cutout.
That's about 25 HP.
Old Nov 4, 2003 | 06:03 PM
JBIRD02's Avatar
I have the LM exhaust, would a cutout help or be pointless? thanks
Old Nov 5, 2003 | 12:42 AM
TNormZ28's Avatar
Well, I can't find my closed cutout run but I remeber it was 13.6X, and my open cutout run was 13.3X. So as I said just shy of 3 tenths. My short times are very consistent as this is an A4 car at 2.1X with a very poorly prepped track and warm/muggy conditions that night. My cutout is installed on the i-pipe before the axle. It dumps to the passenger side and slightly down. The next time I go to the track I will do back to back runs again and make sure I keep my slips from both and label them so you all can see what it does. This gain is over the Corsa Pro Tip exhaust too.
Old Nov 5, 2003 | 12:49 AM
Sniper33's Avatar
JBIRD, I personally don't have a cutout but I'm going to go with yes, it will net you gains if you have the Loudmouth. I believe the only system that a cutout is totally pointless on is a true dual setup. I can't wait to get my QTEC's!!
Old Nov 5, 2003 | 07:27 AM
JBIRD02's Avatar
anyone?
