Header Options to Meet Calif Smog
Old Nov 3, 2003 | 07:18 PM
ls1z01's Avatar
Default Header Options to Meet Calif Smog
I want to know if all headers, long tubes or shorties with cat is consider smog legal. I never see anyone brand that has a OE CARB #? or state that they are 50 States legal. I only see with cats, AIR, etc and Off Road Use Only. But still no advertised OE CARB #.
Thanks!
Tom
Old Nov 3, 2003 | 07:36 PM
highgear's Avatar
Hooker, JBA shorties are supposed to be smog legal as they bolt up to stock head pipes/cats. However, most shorties only give about 12rwhp. So, are they worth it??
Hooker has the best price at around $250-270.
Old Nov 3, 2003 | 09:20 PM
Ferocity02's Avatar
As far as I know, JBA headers are the only one with CARB numbers. You can probbaly get away with Hooker or BBK though.
Old Nov 3, 2003 | 09:35 PM
WS6FirebirdTA00's Avatar
ANY full length header, with cats and all the emissions stuff, i.e. egr tube and air tube will pass inspections as far as i know and is legal. my car blows 190 hc's with no cats, egr or air. and that passes, legal limit is 220 so i would imagine if the exhasut was legal it would be no problem
Old Nov 3, 2003 | 10:13 PM
LS1MONSTER's Avatar
Passing the emissions part is not the problem. Its the visual part where Longtubes or basically anything shiny under car. Thats the problem. I'm in cali so I best find myself a "honest" smog shop lol.
Old Nov 3, 2003 | 10:36 PM
Cal's Avatar
Cal
Anything that relocates the cats, that means all long-tube headers, is illegal in California and the rest of the states as well since it is a federal law. Now what you can get away with, that is another story and may vary from state to state and even with counties and different emissions stations. Most people get away with using long tube headers in most areas including California as long as they have some traditional looking cats, not those tube things. Headers aren't really obvious on an LS1 Fbody. But you may still run into a hard-nosed inspector here and there and have to go somewhere else.
Old Nov 3, 2003 | 10:45 PM
SScam68's Avatar
From Hooker website
This is a 50 state legal header C.A.R.B. E.O. # D-164-5.
1998 LS1 pt #2077HKR
Old Nov 3, 2003 | 10:52 PM
Ferocity02's Avatar
Completely False....
Old Nov 3, 2003 | 11:12 PM
jrp's Avatar
jrp
SN95 Director
werd, especially for cali. alot of people in cali try and stay smog legal by going the shorty route but why by shorties that are almost the same price as LT's and wont get you nearly as much HP. plus if you cant find a "honest" shop then you could always swap out the LT's and install your stock manifolds and Y.
i have LT's and cats, havent had to do emissions yet though. im pretty sure that i could get away with those, its the cam im worried about
Old Nov 4, 2003 | 06:51 AM
well ok then ill change that, in NC for state inspection full length headers pass as long as they have emissions stuff still on them and i know this for a fact seeing i do inspections
Old Nov 4, 2003 | 06:52 AM
seeing NC has tight emissions law i figure that most other states this would pass also but i am not sure but as far as we go in NC i am not wrong
Old Nov 4, 2003 | 08:21 AM
samz28's Avatar
carb stickers are quite expensive. Many many years ago i looked into getting one for a chip. They wanted $25K for a single chip for a single car. For testing,documentation, etc. Was easier to sell parts "for off road use only" obviously since this was a low volume product i was/am making for vw's.
**** cali.
Old Nov 4, 2003 | 11:43 AM
ls1z01's Avatar
Thanks everyone for your responses... I'll look into the JBA or the Hookers and see how they are... any complaints or praise on either one of them?
LS1MONSTER - I'm in Monterey Park... pretty local to you ... maybe we can meet up so I can check out your SLP LTs and see how LOUD they are with our LM?
sscam68 - Great! I'll definately check them out! Thanks!
Old Nov 4, 2003 | 08:12 PM
KrazyDan's Avatar
Hey JRP, when do you have to go in for emissions? When you do let me know what happen so I will know what route to go. I cant wait to get LTs but am putting it off because of emissions. Would cam give you any problems with passing?
Old Nov 5, 2003 | 09:15 PM
KrazyDan's Avatar
ttt..
Old Nov 6, 2003 | 02:04 AM
jrp's Avatar
jrp
SN95 Director
seeing how i just bought the car in july 03' i think im good for 2 yrs. the 230 intake duration and the 110 lsa is whats gonna kill me on the cam :o. im gonna try and pull off a smog tune with it, if that dont pass i'll swap in a 224 on the 112. with a good tune the 112 should pass and the hp loss will be minimal.
im not to worried about the LT's unless i have to go to one of those state inspection places where they check for everything. i think some small whole in the wall asian run facility would be able to overlook them
Old Nov 6, 2003 | 10:04 AM
Cal's Avatar
Cal
Yes, cam's often times give you problems passing, especially if they do the sniffer test. If only the OBD2 plug in test, you might get by just my desensitizing the idle missfire test. The biggest safe bet on a cam is probably a 224/224 on 114 LSA with tuning. Without tuning, better stay with a 218/218 114.
Old Nov 6, 2003 | 05:08 PM
jrp's Avatar
jrp
SN95 Director
well what fun is that . the 224 114 has been proven to pass smog with minimal tuning here in cali. so i'll use that as a starting point. the 112lsa should pass with good tune.
Old Nov 6, 2003 | 08:26 PM
KrazyDan's Avatar
well im aiming at the 224/224 112 and will worry about the smog test later
Old Nov 9, 2003 | 01:36 AM
Bowtieman4life's Avatar
F#%K smog. LT+ ORY+ Magnaflow Catback = power. Most shorties flow no better than the 00-02 exhaust manifold. Change them out every 2 years or pay someone $300 to hook you up.
