nut size for 6.0 truck manifold stud
Old 05-21-2009 | 08:32 PM
02anti_vnm's Avatar
Default nut size for 6.0 truck manifold stud
Ok this may seem dumb to some people but I can't figure it out!
I've done a search about a 100 times
I'm trying to install my turbo kit and I can NOT figure out the size of the nuts for the 3 studs on each manifold where the crossover or whatever bolts to!
Please help that's all I need then ill erase this thread I'm getting tired of running back and forth to the hardware store.
The threads are a little rusted up so that is probably part off my problem if some one could give me the exact specs for the nuts you'd make my life so much easier thanks!!
Old 05-22-2009 | 02:07 AM
TurboZ28408's Avatar
Old 05-27-2009 | 02:08 PM
02anti_vnm's Avatar
they wernt 3/8-16 they were even finer thread then that
but i got pissed off removed all the studs taped the holes and put all new studs in with nuts to fit them
problem solved!!!!!
thanks
Old 05-27-2009 | 05:41 PM
stevieturbo's Avatar
I'd have thought it would use a metric fastener, or is it just the engine on these cars that are metric ?
Old 05-27-2009 | 06:21 PM
Vetal's Avatar
So what thread are they?
Old 05-27-2009 | 06:34 PM
theblur98ss's Avatar
I bought 10x1.5 and they wouldn't work. An 11x1.5 die goes on nice but I couldn't seem to find that size nut anywhere.
Old 05-28-2009 | 03:29 PM
98Z28CobraKiller's Avatar
Restricted User
Mine are M10X1.5
Old 05-28-2009 | 07:01 PM
dhdenney's Avatar
I just took mine to the auto parts store and they had it in about 15 seconds flat. Even had the correct knurled nuts.
Old 05-28-2009 | 10:45 PM
and so what size are they ?
Old 05-29-2009 | 12:56 AM
Boosted 99 TA's Avatar
haha i just took my manifold to the hardware store i got M10x1.5 too, that was for my stock manifods off my ls1 not 6.0's but im sure its the same anyway, make sure the stud is clean
Old 05-29-2009 | 03:25 AM
fyi 3/8-16 and m10 1.5 are SUPER close, once you get 4 turns in is when youll feel or see the difference but most people will just shove it on in
Old 05-29-2009 | 05:42 AM
dhdenney's Avatar
I had no idea. I'd be willing to bet it's metric though.
Old 05-29-2009 | 05:50 AM
Vetal's Avatar
Kinda funny - 12 posts, many solved the problem, but we're still not sure
Old 05-29-2009 | 09:44 AM
ls1290's Avatar
Dumb Ass Vette Moderator
LMFAO because this was the ad banner at the bottom of the page!!!!!
Old 05-29-2009 | 10:44 AM
frcefed98's Avatar
M10x1.5 is the right size for both car and truck manifolds
Old 03-22-2012 | 09:05 PM
PRAY HRD's Avatar
why the hell are mine only going 3 turns and stopping?!
Old 03-23-2012 | 03:06 AM
Maybe you have the wrong size...or someone has changed them
Old 03-23-2012 | 05:25 PM
PRAY HRD's Avatar
maybe i should think before i try things! lol my manifolds came coated and while the studs "looked" ok, they needed to have a wire brush taken to them and then the nuts went on, snug the whole way up but they were the correct size....that being M10 x 1.5's.
glad i found this thread and thanks for the input.
Quick Reply: nut size for 6.0 truck manifold stud
