new edelbrock ls1 intake
I am disappointed to say the least.
It is a small square flange dual plane manifold.
The only reason I could see to carb an LS1 is for racing.
This intake is clearly not meant for that.
For a street application you'd be much better off leaving F/I on it.
Hopefully they got a dominator square flange open manifold in the works!
On N/A pro racing the dominator still rules F/I got a way to go...
what is a carb?
i know it has to do with the fuel delivery
is this some kind of ancient system used by people in the early days?
the thought of putting a carb on an ls1 with electonic timing made me start to drool, but a low rise dual plane setup would not be in the right direction
and carbs are far from ancient, sure they were around before fuel injection, however the advances in carbs is astonishing and for a drag setup, cant beat a carb
We might have seen a lot more intrest.
. I find it hard to believe that someone can doubt the performance capabilities of this intake, before they even have any facts to back it up. This is brand new territory for the LS, lets wait to see some hp numbers before we bash.
This is a RPM intake, for a carb aplication, they have always been dual planes. I'm sure a Victor single plane will be here shortly.
Also, if tuned right, carb will make more hp then EFI. In theory.
he's gonna make money from older guys who want to swap and don't know how to deal with efi or whatever...but please..
what next bias plias tires?
How many EFI systems have you designed?
You make me laugh............at your ignorance.
I personally have no use for it but I could care less if the guy next door wants to pick up 10HP and get 6 MPG
On an older car it could be cool, it would be easier to swap and you'ld have no expensive injectors, massair meters... etc to mess with.
And no damn LS1 edit or paying for PCM tunes!
There were all MECHANICAL fuel injection! Just a little bit of difference there, and I'm saying that sarcatically!
, it's all good and all have merits!
