new edelbrock ls1 intake
We might have seen a lot more intrest.
There were all MECHANICAL fuel injection! Just a little bit of difference there, and I'm saying that sarcatically!
You stated "aftermarket fuel injection," and I answered that. You didn't say wether EFI or mechanical. Bosch were the first ones to develop EFI. It's all really irrelevant anyway, and this post has gone absolutely nowhere. The post was for the acknowledgement of a new product on the market,and intelligent conversation about it, not as a way for "tard-***" draggers to get their panties in a wad and start attacking others because they have a differing opinion than what they believe works. I also clearly stated that Edelbrock was ONE of the first company's to create a complete aftermarket fuel injection system. NOT THE FIRST ONE!
If you don't like the idea of a carb on your engine. Well you're in luck! Because no one is making you buy this thing.
Some people just need to keep their two cents to themselves in this post, because they obviously don't know sheet!
Chris - confused
Lets not forget, one of our biggest restrictions is our LS1 intake design, although the LS6 works well, there is still plenty of room for improvement, hopefully the FAST intake will flow well enough for these large stroker h/c cars.
But at 9000 rpm a "wet" manifold does have advantages.
If your looking for EFI in stock cars where do you think the ASA is running.....
http://www.pro-system.com/scoop92102.html
Sawedoff, I think ss427ci is refering to a naturally aspirated engine, \when the engine has to draw the air in by itself, with no help from a turbo or supercharger. The reason an LS1/6 intake can produce so much hp with forced induction set up is just that, the air is being FORCED through the intake.
Or you could think of it this way. Imagine if you had to run a marathon just breathing through a drinking straw, it's be pretty tough. But if you had a an air tank with compressed air blowing air directly into that staw, you could alot easier. Right?
I always though of each barrel/venturi of a carb as a mechanical mass air flow meter that adds fuel.
They are great for max power, but EFI will always have better drivabillity.
GMPP showed just such a manifold last week at PRI show. Outer runners were about 7 inches long and inners about 4-1/4 or so. Try this for pics.
https://ls1tech.com/forums/showthread.php?t=120327]
This will by far be the cheapest way to go all aluminum V8.
The intake I saw was made by GM if Im not istaken. It would be a great idea for racing if you just wanted a low tech, easy way to build a race motor. No tuning except jetting and timing adjustments.
I seen that on a buddies 5.0 went from 13.80's @ 100 to
12.80's @ 106
yea, i know the math doesn't add up. i worked on the car, seen it race, raced it on the street. it's for real..
only change. box stock edelbrock performer w/ 650 dp to a box stock cobra intake w/ 65mm tb & 73 c&l
mid range increase was amazing.....
"1997-02 Camaros and Firebirds"
__________________________________________
They could do there homework a little better than that.
This set-up is clean. It includes the manifold, a harness that works with the factory coils, cam sensor and crank sensor and it comes with a new MAP sensor for the manifold. You will also receive the ignition box, complete with six different timing curves for various cam grinds, and a throttle bracket for your throttle and TV cable. From there the customer only needs the proper motor mounts and accessory brackets. For those wishing to run a TH350 or TH400, a new flexplate, along with a crankshaft adapter sleeve will properly align the torque converter with the input shaft of the transmission. Clean, simple and cost effective. Just as I said on a reply above, this product should be embraced as it will further solidify the LS1's place in the market. The deaper the roots the LS1 has in the market, the more products companies like Edelbrock will bring to the market.
