LS6 intake??? pn 12561184??
Old Nov 6, 2003 | 03:02 PM
Z06PSI's Avatar
Default LS6 intake??? pn 12561184??
Someone please verify thanks
Old Nov 6, 2003 | 03:09 PM
Sheomet's Avatar
Isn't that the # for the LS6 block?
Old Nov 6, 2003 | 04:16 PM
Z06PSI's Avatar
Well the intake I just bought has this PN right above the cylinder firing order...... do I have the wrong number....????
Old Nov 6, 2003 | 04:47 PM
jrp's Avatar
jrp
SN95 Director
just look at the bottom of the intake, if its flat you have an ls6, if its not you have an ls1. i have an 03 ls6 intake, forgot the part number, i can it get for you later if you like.
Old Nov 6, 2003 | 04:51 PM
Z06PSI's Avatar
Please.... I have found 3 different pn#'s for this intake and just wanted to make sure I didn't get screwed before I put it on...
Old Nov 6, 2003 | 04:55 PM
jrp's Avatar
jrp
SN95 Director
ok, just checked mine: 12573572
there are i believe 3 different numbers for the same ls6 intake though. i know mine is the 03 and theres one for the 01 and 02's too, i think.
Old Nov 6, 2003 | 05:34 PM
Z06PSI's Avatar
This is frustrating.....
Old Nov 6, 2003 | 05:44 PM
jrp's Avatar
jrp
SN95 Director
where did you buy it from? do you have it yet or still waiting on it. if you have it then just check the bottom, if its flat its an ls6 intake. if your still waiting on it wait till it comes in then check it. which ls6 intake is it is doesnt really matter :shrug:
Old Nov 6, 2003 | 06:27 PM
Z06PSI's Avatar
I have it and it is flat......thanks for the help....
