A little warning about QTP cuttouts...
I had been noticing a little leakage for quite some time. It would seal when I tapped the switch closed but then it would back off just a little after awhile and then leak again. I developed a habit of tapping the switch every so often to reseal it. Well, the other night I opened it in the parking lot of a restaurant (needed something cool to listen to while I waited on my girl and I didn't have any good CDs handy) and it wouldn't close back. Well, I leave the restaurant and within a 1/4 mile or so the thing closed on it's on! Well, mostly closed. It still leaked but I wasn't worried about cops anymore. When I got home I just had to know what was going on so I pulled it. The three screws that hold the motor case together were loose (they can't actually fall out because of the plate above them) causing the case to spread out which caused the gears on the inside to loose contact. The blade freewheeled as a result. So, I tore the thing apart (I didn't go into the motor/gearbox) and put it back together good and tight. I would have used some loctite if I'd had some at the time. If it does it again I'll get some. While I had it apart I applied a thin bead of RTV silicone to the surface that the blade makes contact with and let it sit over night open for it to cure. I thought this would help it seal even better and it's what QTP had suggested awhile back for me to do.
Anyway, it's worked absolutely perfect ever since (no leakage whatsoever.)
I would recommend that people loctite everything before installation and I would also recommend that QTP (Barry, you listening?) start using loctite on them so that we don't have to.
The 4" qtec are going to be ready very shortly.
Any questions feel free to call us. Anyone here can help.
Gotta love QTP customer service! What do you think of making my idea of loctite a factory installed feature? It's just a drop here and a drop there so it really shouldn't add anything to the manufacturing costs. The red kind might be a bit excessive strengthwise but maybe some of the weaker stuff? It might get you up to 99.99%!
