Fix Cracked FAST 90 intake
Old Jun 26, 2009 | 01:02 AM
jwill_20's Avatar
Default Fix Cracked FAST 90 intake
My buddy's 02 Procharged Trans Am has a FAST 90 intake manifold and last week on the backside of the intake manifold it cracked and broke a chunk out of the back. I was wondering if there is any way to fix the intake (plastic weld, epoxy,etc?) or should he not chance it and fork out the dough for a new one?
Old Jun 26, 2009 | 09:23 AM
JFM-jr's Avatar
There was a guy here that tried to repair a cracked FAST and was not successfull. He was not FI either i'd say the fact your buddy is running boost is gonna pretty much rule out any fixes.
Old Jun 27, 2009 | 04:25 PM
jwill_20's Avatar
thats what i was afraid of...it hard to bite the bullet and buy another one..esp. since they are a little over a grand all said and done...anybody else got any ideas???
Old Jun 27, 2009 | 04:37 PM
thunderstruck507's Avatar
where is it cracked? maybe replace the upper shell only
or buy an aluminum intake instead and sell the lower/middle shell
Old Jun 27, 2009 | 04:58 PM
black01_WS6's Avatar
have him look into a Vic jr. or GMMP intake for FI they are great. He can also get a ls6 intake and call it a day.
I wouldn't use a broken fast with boost even if it was fixed. Also Fast used to sell just the bottom piece, but doen't offer it anymore, he may be able to hit up a couple of the sponsors and see if they have one left over and be able to fix it cheaply and fix it right.
Old Jun 27, 2009 | 05:16 PM
Mean Green z28's Avatar
buy only the part the of the intake that cracked. which part cracked? The black or the top (gray?)
Old Jun 27, 2009 | 08:17 PM
jwill_20's Avatar
well not sure how extensive the damage is, its still on the car, bot its on the back side of the intake under the cowl.
Old Jun 28, 2009 | 08:14 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
The problem with a boosted motor is that the intake manifold will not only see boost, but also vacuum, so it's going to get pushed/pulled and never hold up after being fixed.
I've heard people say that there isn't much difference between the fast and a ls6 intake when you go into boost, so an ls6 intake may be a good alternative.
Old Jun 28, 2010 | 11:55 PM
robo9877's Avatar
Default help!!!!!!!!!!!!!!!!!!!!
my intake is cracked right at the front is there anything i could do to patch or fix it no boost on my car
Old Jun 29, 2010 | 12:12 AM
01ssreda4's Avatar
plastic weld 2 part epoxy. $5 at the auto parts store.
Old Jun 29, 2010 | 12:52 AM
garygnu's Avatar
I like the moroso epoxy .
Old Jun 29, 2010 | 06:43 AM
SweetS10V8's Avatar
I would just get the new FAST 102mm, it can handle more boost than the old 90mms. They say its good to 67psi, I could tell just by holding it was a much more solid piece.
Old Jun 29, 2010 | 02:25 PM
chrs1313's Avatar
Devcon 5 minutes 2 part epoxy...make sure to sand and rough the surface up...also 1/16 holes help too if need be...worked great on my intake when I wanted to over port some areas and fill some in... I am n/a though...
worth a shot
Old Jun 29, 2010 | 03:10 PM
UNDER PRESSURE MOD
Is it really worth it if something brakes free and gets ingested?
Old Jun 30, 2010 | 06:01 AM
taman86's Avatar
ya once you go boosted it really doesnt matter what intake you use, there wont be that big deal of a difference, not like heads, and the fast from what i have heard doesnt stand up well against boost or nitrous when it backfires into the intake, and your friends intake just proved it. if anything i would look into an aluminum, maybe a bit heavier but heavier is sturdier and is more resilient.
