Motor Mounts LS1...??? HELP???
Old Jul 6, 2009 | 04:25 PM
WARP211's Avatar
Exclamation Motor Mounts LS1...??? HELP???
So I got the driver side done.. now im doing the passenger side and I gotta a little problem....My question is:
1) Can I change the motor mount one this side without having to disconnect the A/C Lines to the compressor? Can I just unbolt the bracket push it foward a little without having to break the system??
Old Jul 6, 2009 | 09:04 PM
aothepresident's Avatar
Yes, you can just unbolt the bracket and push it forward without disconnecting the lines. It's a royal pain though. Take your time, you'll get it done
Old Jul 6, 2009 | 10:20 PM
Mumbles's Avatar
I agree 100%. If you want a detailed thread of removal and reinstallation, this one here is really good. Good luck.
https://ls1tech.com/forums/generatio...r-written.html
Old Jul 7, 2009 | 07:00 AM
1979rs/z28's Avatar
Yeah just slide the ac compressor forward. I removed the starter also on that side for more room.
Old Jul 7, 2009 | 11:21 AM
WARP211's Avatar
Awesome guys thanks for the info.. One quick question tho.. When you have the new poly mount in the clamshell does it have about a 1/8 in. of gap or does you're guys sit flush with the clamshells?
Cuz I have mine in but there's that little gap and I called poly and they said they didn't know if there should be a gap or sit flush with the clamshells??? Anyone know??? I can take pics if you need them..
Old Jul 7, 2009 | 02:00 PM
Mumbles's Avatar
If you would post a picture that would be wonderful. I'm not really sure what "gap" you should have. By the sound of it, I don't think it should be there. Like a said, if you post a pic, then we could get a good look at it.
Old Jul 7, 2009 | 09:31 PM
WARP211's Avatar
Old Jul 7, 2009 | 09:38 PM
WARP211's Avatar
if you look at the pic you can see one side of the mount sits flush and the other is almost all the way in..!! Do I just need to press it in more?? So the other side can sit flush..
Old Jul 8, 2009 | 02:43 AM
LCplmarine98's Avatar
If you have the headers off do you still need to remove all the A/C stuff?
Old Jul 8, 2009 | 05:50 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Once you bolt the clamshell back together, it will seat the mount in the bracket perfectly.
Old Jul 8, 2009 | 03:11 PM
01ssreda4's Avatar
i agree, those polys are really tight fits. thats what you want though.
Old Jul 8, 2009 | 03:14 PM
Mumbles's Avatar
Yeah, you should. Its much easier with the A/C outta the way to get to the clamshell bolts as well as reinstalling the long motor mount bolt.
Old Jul 8, 2009 | 03:22 PM
Mumbles's Avatar
Agreed. When I did mine, I tightened the bolts corner to corner a little at a time. That way you sorta allow the bushing to gradually work into place. Maybe overkill, but it worked pretty well for me.
Old Jul 8, 2009 | 10:37 PM
WARP211's Avatar
Yeah thanks fellas.... I just need to use the bolts from the kit and it seated perfectly now...!!
