Free Ram air is sucking up water and mud
Hey guys,
I thought I'd post this as a warning to everyone, heads up, whatever you may call it.
I pulled my "lid" and SLP "bellows" off of my car to go truck shopping today. I can see where my lid, mass air and throttle body have calcium like deposits in them from where water has been finding it's way through the filter and into my throttle body. The K&N filter had a layer of dirt that filled the pleats of the filter completely (right above the hole from the free ram air). My car is driven around town and back and fourth to work as a daily driver. I have not run through any large puddles lately or ever that I can think of and the layer of deep dirt would be from more than one time of getting wet. It appears that the road spray is getting sucked into the intake, through the filter and clear into the motor. I don't consider this to be a good thing. I'm going to build up a baffle to go in there as soon as I have time and see what that does for me. I just thought I'd throw this out, I'm sure I'm not the only one that will find this once you pull the lid and look. Has anyone else found this with their car?
wierd, I've had my free ram air for over a year and had NO issues with water or mud. I've even went thru water that went up to my doors, a F-350 going by me at 10mph (with water going over my t-tops), pulled into a gas station and checked EVERYTHING. the engine was soaked but the filter, MAF, throttle body was completly dry. I also have a daily driven, drive in rain all the time and I have had no issues with water or mud. my filter stays dry.
yeah im running about the same set up with a fast toys ram air kit on it and i havent noticed any acumulation. just the filter is noticalby durtier above the slot for the ram air kit... thats weard... maby you can try some clean t-shirt fabrick under the air filter... sorda a pre filter.
Could possibly be that the filter was extremly dirty and the small amounts of condinsation that gets to the filter from cold air(winter time) were not able to be soaked up by the filter because of it being so dirty.. Dunno, only think I can think of.. Ive never had any problems.
My filter gets dirty as hell like you said. Mud and dirt and road crap all over, never had a problem of any of it passing through the filter though. If it matters, I'm running a Holley filter.
A few years ago when I first did the FRA mod my car was still a DD. I was somewhat wary, so I took it out on one of the nastiest, rainiest days I could find (didn't have to look far here in Seattle area ). I drove on the freeway next to big trucks, etc., and got thoroughly hosed down. Went home immmediately after a good soaking and pulled the lid and air filter. Filter was dry and I saw no evidence of moisture having gotten up more than a few inches past the air dam underneath. I also watched as the wife drove through shallow standing water and noticed that the spray created by the front tires was too far back to get into the intake area. I imagine that deep standing water or the like could cause a problem, but I never had experience with it.
Unfortunately, that doesn't help your problem...
I never sucked up water but the SLP Cold Air Induction that came with my car was "free" to vacuum up all kinds of dirt, debris, leaves, sticks. I put the BG Ram Air in and pulled that metal POS out and used sheet metal to plug the hole. Now my radiator is unschrouded, air is directed through it now. My filter is very clean and I get a functional Ram Air as well as a cooler engine. Plus I saved 9 pounds in the process.
55,000+ miles on FRA and K&N with sealed lower air box. No problems! It rains alot here in SE MO and mine is a DD. I did go through a 5-6" deep, 50' long "puddle", at about 2 mph, and there was dirty water under the filter where the FRA cut was made BUT! No water past the filter.
Don't drive your car like you drive a submarine and you should be fine.
I've never had a problem with my FTRA in 29,000 miles of rain, snow and sun. Maybe you've got a leak somewhere else?
Originally Posted by trackbird
Hey guys,
