Pics of TSP's New Catted Y-Pipe!
#44
I have been eying the TSP setup for a while now, but I'm still nervous about passing emissions testing in New Hampshire.
I fully understand, legally, they can't officially claim to be 100% emissions friendly without the costly certification program.
That said, If I got a set of TSP headers / catted Y pipe, would I pass a visual / OBDII test (assuming all necessary steps are taken -- O2 sims / codes disabled, etc.) in New Hampshire? Let's assume the inspector isn't a jerk who simply sees headers and fails a car.
Also, I guess I could ask, would the exhaust mix pass a sniffer test with these bullet-style cats?
Thanks for answering.
#45
the fact LT headers relocate the cat's from their original location is the reason they are not "legal". if the inspector is not **** and see's you have cat's then you should be ok. or find a place that you can pass at.
#47
LS1Tech Premium Sponsor
If it is a shorty style JBA header it will not bolt up to our y-pipe. We have not tried, nor heard of anyone using the long tube versions and connecting them to our y-pipe. Though I'm sure it's close enough that they could be made to work with possibly a little modification. Our y-pipes currently do not include the rear o2 bungs. You would need to turn the rear O2's off in the tune.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic211066_2.gif)
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
