picking the right manifold
Old Jul 18, 2009 | 02:04 PM
Gold98SS's Avatar
Default picking the right manifold
i have a torquer 3 cammed ss with full exhaust, i was wondering if a stock ls6 would be good enough, or should i look into a FAST, or something like that? thanks
Old Jul 18, 2009 | 02:27 PM
Rossi396's Avatar
What is "good enough" for you? The FAST will definitely outperform the stock LS6 intake.
Old Jul 18, 2009 | 03:15 PM
Gold98SS's Avatar
well i'm looking for the best bang for your buck i guess. someone told me not to trust typhoon intake manifolds. do you know anything about that?
Old Jul 18, 2009 | 04:07 PM
Rossi396's Avatar
Don't know about the Typhoon. The LS6 is definitely an upgrade over stock. You can get an LS6 for around $300.00. You may want to do that considering it'll help out the rest of your bolt-on mods at a reasonable price. FAST is gonna run you around $850.00. In short, it all usually comes down to how much you want to spend...!
Old Jul 18, 2009 | 04:36 PM
Gold98SS's Avatar
Alright. Well thanks for the input. I will look around a little more and look more into a typhoon too. I will let you know
Old Jul 18, 2009 | 07:00 PM
khaotic's Avatar
Default Intake results
Here is a link on some intake testing and result I have also found them to be good Look at the rpm range and throttle bodies used to get results and look at the cost differance for the hp gains hope it helps you decied
http://www.tpis.com/index.php?module=2_17_06
Old Jul 18, 2009 | 10:31 PM
99Ls1fever's Avatar
I would just run the LS6 Intake there are numerous cars on here making over 700 hp still using the LS6 inatke. Will the FAST outperform the LS6? Yes, but for 1,100 dollars I would rather buy PRC 2.5 Heads and get another 30-35 hp gain and then worry about the FAST. Or then after the Heads keep the LS6 Intake and just get Nitrous and then you will have as much Horsepower as you Need.
Old Jul 19, 2009 | 10:36 AM
Gold98SS's Avatar
Ok. So it sounds like the ls6 would be the best deal. One last question, my car is tuned for a 175 shot. Would the ls6 manifold mess with it at all? Or what im trying to say is would it be best to get it re-tuned or should it still run alright?
Old Jul 19, 2009 | 10:54 AM
99Ls1fever's Avatar
The LS6 Intake is Fine with a 175 Shot. On my LS6 I have ran a two stage Nitrous setup with a 225 shot on it before. I would get a re-tune for saftey issues though. Best of Luck. Throw some pics of your ride up
Old Jul 19, 2009 | 11:28 AM
Gold98SS's Avatar
alright thanks and i'll try to get some pics up as soon as i can
