lt's, which o2's?
GM now uses Densos for their own AC Delco 02 sensors now. They charge upwards of $160 for re-boxed Densos.
Bosch are garbage.
GM now uses Densos for their own AC Delco 02 sensors now. They charge upwards of $160 for re-boxed Densos at the dealerships.
Bosch are garbage.
I doubt GM would choose these as their 02 sensors if they're were any problems with them at all.
I can tell you this though...Bosch...my engine will simply not run with them and I know quite a few people that have the same results. Horrible.
You will be completely satisfied with Densos.
I have looked at 2-300 sets of them while logging and I can SEE them switch better at low engine speeds.
GM's choice of sensor isn't (or shouldn't be) relevant here; GM didn't choose long tube headers for the cars, they used cast iron manifolds.
I don't sell them, so it's not like I am making this up to push an agenda.
My 427ci went in in 2002. I continued to use my original factory sensors from 1998 with my 427ci. About 4 years ago one of my original factory AC Delco sensors went out (had 3+ years with my 427ci in LT's on them).
On my way to Mecedo Motorsports to use their lift I stopped and bought two new Bosch sensors. We put them in and the engine would literally hardly stay running. The scanner showed they were working properly though. I jumped in my friends car, brought them back and got a full refund. Then went to the dealership and picked up 2 new AC Delcos, put them in and instantly the engine was perfect. I drove off.
This year, about 5 months ago, one of them went out. I ordered two new AC Delcos from Bennett for $180.00 for the two of them. I got there to pick them up, opened the box and I found Densos in there. I had the guy pull two Denso plugs off the shelf to look at them and they were 100% identical. But they were $120.00 for both. So I bought them. They're perfect in my LT's.
My friend at a Pontiac dealer confirmed that GM uses Densos now.
Why doesn't GM use Bosch....because they have way too many problems across the country, its common knowledge that they either work or they don't. That means they suck overall. I don't anyone that has ever had a problem with Densos, but Bosch, you hear it all the time.
But you can buy whichever ones you want.
