Help Me ID this Noise *Video*
Old Aug 16, 2009 | 04:30 AM
Soul TKR's Avatar
LT headers in general will give you "header tick"... just something about having LT's on a car that gives everything a different sound. Not saying that's your problem, but it could be. Mine have a "tick" to them. But they don't seem near as bad as yours... my 2nd guess would be valvetrain. Very well could be a bent pushrod... loose rocker...
Old Aug 16, 2009 | 10:13 AM
98cherrySS's Avatar
^^^Should have mentioned that^^^ It would be worth pulling the valve covers and inspecting the rockers and the pushrods... A missed shift is all it takes to bend a stock push rod.
Old Aug 16, 2009 | 09:07 PM
cjtzcar's Avatar
Here is a another check, a lot of the answers so far are good answers but I have run across a coil arcing or grounding and that will make a tick similar its a easy check just look at it in the dark you will see it if its there. Another thing worth noting is to me it does sound metal against metal but nothing to major sounding, could be what others have suggested, but it could be a wrist pin also. Without actually being there it is hard to say.
Old Oct 12, 2009 | 05:36 PM
dondb's Avatar
Did you find the problem?
My car sounds exactly like yours after i had a comp cam 224/224 LSA 12+4, new springs, 7.425 hardened push rods, LS2 timing chain and UD Pully. My installer tells me it is normal and is the more aggressive set up. So as others said, it could be normal?
Old Nov 6, 2009 | 09:09 AM
miamifan3413's Avatar
Im having the same ticking sound but mines coming from the drivers side....I can hear it from the top and when i get under the car on that side i hear it also. I thought it was exhaust leak but it's not. I checked plugs, plug wires, coil packs but still get the same ticking sound. It very irritating! My ride seems fine and runs good....cant figure it out. I'm really starting to think its an internal issue. I'm thinking rocker arm or pushrod.
Old Nov 7, 2009 | 12:52 AM
pheer's Avatar
my car makes the same sound.... so did my 2006 impala SS with the LS4.... i always thought it was normal....
and as someone else said, it goes away mostly once the engine is warmed up, at least my tick does....
also, the cold most definitely makes it worse...
Old Nov 7, 2009 | 08:17 PM
Mine is loud like in the video and never goes away at all....it has done it ever since i installed headers and catback.
Old Nov 7, 2009 | 08:30 PM
Keith_Shapiro's Avatar
same problem here i go under alot of bridges and tunnels and it pisses me off, i cant figure it out for the life of me hopefully someone has an answer besides "normal" for this!!!
Old Nov 7, 2009 | 09:21 PM
PassoutWilly's Avatar
Mine makes the same noise, has been making it since day 1. Just got used to it and assumed it's normal.
Old Nov 8, 2009 | 02:00 AM
therobman's Avatar
its an ls1 get used to it , its a noisy engine nothing wrong
