My Victor Jr Install
Old 08-18-2009, 12:58 AM
conde'strans's Avatar
Nice! I've always wanted this intake it just looks mean under the hood! Hopefully I get to check it out in person someday if you drop by EIRT.
Old 08-18-2009, 04:14 AM
w3s1c0a5t's Avatar
I agree with the lack of tuning with this intake.
Wrong cam weak tune and bad elbow i think highly contribute to this intakes name as a " 600+ stroker intake".
Also such things as people not wanting to adjust fro the higher powerband. Either in the form of too tall a gear or some low stall.
Old 08-18-2009, 04:19 AM
jmill96Z's Avatar
I have moments when I regret going with the Vic Jr. I retuned, but really need to re-cam to about a 110 LSA from my 112+4. Mine runs like a raped ape from 3500+, but won't launch for ****. Hopefully I'll get some clean runs soon with my 4150 setup with BS3 and a 350 shot. That'll make it all better
Old 08-18-2009, 07:34 PM
StreetStalkerZ's Avatar
Get the cams swaped and you will notice a difference in the low rpm band. My cam is setup on a 108 +2 degrees advance and i hardly notice much low end loss,if it lost any it's only from idle to around 2200 rpms during daily driving. My LS6 intake died off pretty fast on my setup becuase you could feel and hear the engine stop flowing air around 6000 rpms and stayed flat to 6700 rpms but with the Victor jr and 4150 it revs much faster and does not stop pulling and the power is much smoother but it's not for everyone.
Cam,4150 throttle body and tuning is what will make it work and most people will not make the commitment to do any of the 3 so that is why the victor jr IMO gets a bad rap for low end loss or bad daily driver manors.
Old 08-22-2009, 04:26 PM
02SOMWS6's Avatar
when the cost was broke down a couple of post before my yaw dropped. I thought it was suppose to be cheaper than a fast. I just picked up a rolling chasis so I'm starting over and when you break it down it makes it seem like a used fast or a new fast is the way to go over the victor Jr. set up. I was thinking I could save som money going with this setup over a fast, boy was I wrong. Good luck with it guys and thanks for breaking down the TOTAL cost with every little detail
Old 09-01-2009, 08:59 PM
SHovV's Avatar
how it goin with the tuning?
Old 09-26-2009, 12:35 AM
lazylongboarder's Avatar
I had 170* IAT temps on a 65* night with similar sensor mounting. Put it in your rubber/silicone intake hose before the elbow. Intake regularly sees heat soak. Can't pull enough timing.
Old 09-26-2009, 11:27 AM
s346k's Avatar
any track results after the swap?
Old 09-26-2009, 03:49 PM
rmata's Avatar
Really? Where are you located at, lol. I'm in Texas where it's how as hell and I rarely see my IATs get over 100. I have anothe sensor at the front where my volant is, but I didn't like the way it looked with the wires stretched out that far forward and it's never given me a reason to use that one anyway.
Old 09-26-2009, 03:59 PM
rmata's Avatar
No, I actually got rained out the day I was going and haven't had a chance to try again. And I just bought another Victor JR with spray bars installed so I can run a dual nitrous setup, so hopefully as soon as that comes in I can go get some test runs. I'll do a motor pass, 1st stage only, and then both. Hopefully my stock bottom end will stay together, lol.
Old 09-27-2009, 08:28 AM
WAHUSKER's Avatar
On paper the Vic should make more hp than LSx intakes on the top end, but they don't make as much tq down low.
One note for you & others about the Vics. There have been a few instances where the fuel rails loosened up & the injectors sprayed fuel on the engine / headers. A buddies car burned up from it. So MAKE SURE all those bolts are tight & stay that way - locking nuts, locktite, lockwires, whatever it takes....
Mark
Old 09-28-2009, 08:49 PM
  #32
burlst/a's Avatar
Default vic jr
well i got the vic on my mustang swap with the low profile elbow.and i have no loss of torque at all.pulls steady from 1000 to 6200 with my stock cam and i love this intake cant wait till i get turbo on it.
Old 03-19-2010, 09:34 PM
  #33
Duffster's Avatar
rmata, you ever get in any track runs? Have any good shots of your vacuum line setup? I see your PCV stuff is gone. Anything else special I'm missing w/the setup?
Old 06-23-2013, 03:45 PM
  #34
monchis's Avatar
Any track times??
Old 06-23-2013, 03:46 PM
  #35
monchis's Avatar
No track times?
Old 06-23-2013, 11:49 PM
  #36
LilJayV10's Avatar
Originally Posted by deadmanTA
I went from LS6 to vic jr and then back to the ls6. Top end power fells the same it's the lower and mid range loss I didn't like. The vic's do look good under the hood though.
Did you change the cam when you changed the intake?
  #37
LilJayV10's Avatar
Nevermind. I just saw how old the thread is. LOL
Old 06-26-2013, 01:06 AM
  #38
LS1MCSS's Avatar
Originally Posted by monchis
No track times?
That post is over 3 years old,, LMAO.
Old 06-26-2013, 09:41 PM
  #39
2nd Gen Fl 'bird's Avatar
......but you took the time to read AND comment on it. Oooooookay.
Old 06-26-2013, 10:10 PM
  #40
blackls1ta00's Avatar
im going with the vic jr and accufab 4150 on my 408 and had the cam matched to it!!
Quick Reply: My Victor Jr Install
