Need help with throttle cable adjustment.
Old Aug 31, 2009 | 08:36 PM
2kblackgtp's Avatar
Default Need help with throttle cable adjustment.
I bought a used BBK 80mm tb of someone. The throttle cable now has enough slack in it that its only half open. I searched but could only really find information that made no sense to me. Since it seems to matter, I have a non TCS car... Can someone please give me a detailed explanation or something with pictures that make me understand how to adjust the stupid cable? I've seen how its done on TCS cars but it doesnt seem like its the same for non TCS cars. Thank you
Old Sep 2, 2009 | 01:04 PM
2kblackgtp's Avatar
Bump, anyone?
Old Sep 2, 2009 | 01:52 PM
teke184's Avatar
follow the throttle cable from the TB back, there is an adjustment back near the cowl.
if you look at this picture, the "adjustment" piece is back by the cowl, directly over the red valve cover.
Old Sep 2, 2009 | 02:42 PM
Hamrdown's Avatar
^that is for a car equipped with traction control^ his as well as mine does not have that adjustment in the line. I would like to know how to do this as well.
Old Sep 2, 2009 | 03:21 PM
jimmyblue's Avatar
Moderator
Take the pedal arm out of the car, and bend it so it has more of
an angle.
Old Sep 2, 2009 | 04:18 PM
2001SS_stompinsupras's Avatar
i also dont have TCS, I would like to know how to do this as well.
im sure theres a way besides bending, no offense
Old Sep 2, 2009 | 05:26 PM
tals7's Avatar
Smile
i also have no tcs cable.my msd tb has multiple holes for end of cable and also is able to be re-clocked(part where cable hooks to cam/arm.).
Old Sep 2, 2009 | 09:54 PM
eallanboggs's Avatar
Doesn't it have a lead crimp that acts as the "rough" cable stop adjustment? Most cable have some sort of sleeve crimped on the end to act as a stop. I would go to a good fishing supply store and find the Seven Strand stuff. Seven Strand sells steel leader(wire rope or cable) to catch big offshore fish(tuna, mackerel, amberjack, etc.). The sell sleeves of all sizes to match different diameter leaders(cable). Just match your cable to their leader and buy the appropiate Seven Strand sleeves. They come in a small pack. You'll need a good crimp tool which you can buy at the sporting goods store or at an electrical supply house.
Old Sep 3, 2009 | 04:10 PM
so it cant be done without "inventing" something?
Old Sep 3, 2009 | 04:29 PM
tals7's Avatar
Question
what is your prob is it not opening all of the way when you put acc ped to the floor?.
Old Sep 3, 2009 | 05:53 PM
Bluvette28's Avatar
i had teh same prob the plate that connects to the intake manifold and the throttle cable i used a grinder to cut where the 90 degree bend is and then i bend it to where i needed it to fit. Works perfect 2 years and no problems
Old Sep 3, 2009 | 05:57 PM
wow , i dont think u even read the thread.
one, its not My thread.
two, the answer to u'r question is the 1st and 2nd sentence in the beginning of the very first post.
Old Sep 3, 2009 | 06:00 PM
bluevette do u have a pic?
so now instead of a 90 degree bend, it more like a 45' toward firewall?
