PCV fitting for a 99+ LS1
Old Dec 1, 2003 | 10:16 PM
bomax's Avatar
Default PCV fitting for a 99+ LS1
I got some Patriot heads which of course use the newer center-bolt valvecover design. I got the valvecovers but unfortunately they do not include the PCV hardware. The passenger side is fine, but I can't find any fitting to go into the hole on the rear drivers side valvecover.
What do y'all recommend?
Old Dec 3, 2003 | 07:55 PM
WILWAXU's Avatar
to the top
Old Dec 3, 2003 | 08:46 PM
HOTROD98Z's Avatar
Your probably gonna have to get it from the dealer unless you can find a junker somewhere, i'm not sure but GM may only offer the fitting as part of the valve cover.
Old Dec 3, 2003 | 09:26 PM
AZLS1's Avatar
Matt,
I went to Ace Hardware walked around for 10minutes and pieced together a nice system for under $10.
Old Dec 3, 2003 | 09:32 PM
ApacheDrill's Avatar
Replace the valley cover with a ls6 valley cover and use 6 inch piece of tubbing to connect valley cover to throttle body with a pcv in between. Not sure the pcv part number i used. I can check it out if your interested.. The new system virtually elimanates oil consumption as well.
Old Dec 4, 2003 | 12:22 AM
bomax's Avatar
Originally Posted by AZLS1
Matt,
Details, please.
Old Dec 7, 2003 | 04:23 PM
AZLS1's Avatar
Matt,
I took the rubber o-ring out of the driver side valve cover and found:
1. A rubber stopper with a hole in it that fit snug into the o-ring.
2. I put a hose connector in the hole.
3. Put a rubber fuel hose onto the other half of the connector.
4. Put a "T" hose connector on the other end of the hose.
5. I ran a hose from the pass side valve cover and also plugged it into the "T"
6. Used another hose from the "T" where the other two hoses were now connected and plugged it into the intake.
If you have trouble finding this stuff, I can put together a kit for you.
*Edit I forgot to mention that after the "T" I plugged in the PCV valve.
Old Dec 7, 2003 | 07:06 PM
bomax's Avatar
Cool! Thank you Sterling! I will give this a try and report back.
Old Dec 8, 2003 | 05:05 PM
bomax's Avatar
Actually I found a perfect adapter at Lowes
Old Dec 8, 2003 | 06:29 PM
SSean's Avatar
sweet, now get that SOB running and lets take her to the track this Wed
Old Dec 8, 2003 | 07:03 PM
bomax's Avatar
It's running
Old Dec 8, 2003 | 10:40 PM
SSean's Avatar
running in place. I want to see the thing move! (under its own power)
