finally got my LS1 started!!! strange prob though...
WHATEVER YOU DO, DO NOT DRILL THE HOLE IN THE TB ANY LARGER THAN WHAT IT IS.... YOU CAN **** IT UP, THATS A BS WAY TO TRY AND FIX IT AND IT WILL NEVER WORK RIGHT!!!! Its 100% in your tune, Bring it to a acutal shop and get the tune looked at.... I had the same problem when i did my cam, I tuned it properly and now it runs great.... Do not listen to anyone that tells you to drill the hole.....
i know the diablo handheld can read it, that's how i ruled out my tps and IAC when i had the problem. other tuners probably can as well. see if you can find a member in your area with one.
