Lessons learned...header and exhaust install
On the driver side I couldn't get the pacesetter header in, was just barely hitting that stupid tab on the engine block. I don't own a grinder and it looked like a lot of work to grind it off even if I did. I just took out the steering knuckle, came out with two bolts, took like 5 min to take it out and then the headers slipped right in like nothing, then took another 5 min to slap the steering knuckle back on.
After installing the headers I started installing the Y pipe. I gotta tell ya that thing is kind of a PITA. I thought I had it pretty well tucked under but lowered the car back down and the clearence is terrible. I need to go back under there and loosen some clamps. Its the driver's side I think can at least go almost another inch up under the body.
Do a search for a thread by twitchtwice and he has some pics that helped my get my y-pipe on the correct way.
I found it fit better if you put the cat'd pipe into the Y and have someone else put their side onto the header as you put the other side on the header. Seemed to work better that way for me.
. had a custom Y made so i dont know you pain on the y pipe.
