intake gaskets?
Old Oct 6, 2009 | 07:29 PM
DCC!!'s Avatar
Default intake gaskets?
if i was going to swap out my ls1 intake with a ls6 or fast would i need new gaskets of could i just used rvt slicone insted?
pretty new to ls1 so sorry if its a stupid question lol
Old Oct 6, 2009 | 07:35 PM
NemeSS's Avatar
gm or autoparts store carry the gaskets.
do not use silicone!
Old Oct 6, 2009 | 08:09 PM
Wesmanw02's Avatar
Exactly!! LS motors use a dry intake, no coolant passes through the intake manifold. In order to seal the nylon composite intake to the aluminum heads, the proper neoprene gaskets must be used. The intake has grooves for the seals to sit in, and when installed they seal to the machined aluminum surface of the cylinder head when the bolts are torqued to spec.
Old Oct 6, 2009 | 08:27 PM
sixpack_2_go's Avatar
LS gaskets are rubber gaskets that are inset into the groves around the ports. i have done 4 or 5 sets on customer cars and a set on my car. you can pick up a set for fairly cheap and just pop the old ones out and press the new ones in with your fingers. its very simple. make sure you clean around the ports on the heads so they gaskets will properly seal. do not use silicon. be sure not to over-torque them. good luck and have fun!
also, the intake has a torque sequence.
http://www.ls1howto.com/index.php?article=5
this link should tell you everything you need to know.
Old Oct 6, 2009 | 10:49 PM
DCC!!'s Avatar
damn so i cant used the same ones? what about valve cover gaskets? can you reused thoses??
Old Oct 8, 2009 | 06:39 PM
DCC!!'s Avatar
anyone?
Old Oct 8, 2009 | 07:40 PM
i would not recomend using the same ones on the intake , they are probably worn out. you may be ok reusing the valvecover gaskets, unless they are already seeping. again, i don't recomend reusing the gaskets, and i don't understand why you would. i think it's like $10 for valve cover gaskets and only $16 for intake gaskets. doing an intake is kind of a pain in the *** so, you might as well do intake gaskets while you got it off.
Old Oct 8, 2009 | 08:23 PM
DCC!!'s Avatar
ohh thats good then i figure they would be much more expencive and i have very little money right now anyways
