Just Installed BBK Intake
Old Oct 29, 2009 | 10:39 AM
BIG_MIKE2005's Avatar
Originally Posted by 1998CruzMssl
Did u have to reroute coolant lines at all? I just ordered my bbk.
I'd just buy the cheapo coolant crossover conversion. It eliminates the entire coolant line under the intake. Which will eliminate needing to modify anything.
The black one pictured above is a friend of mine & member on here ChevyChad. That intake is on a forged 370 w/F1 Procharger.
Old Oct 29, 2009 | 10:49 AM
blakern's Avatar
Im glad to see this intake gaining some credit. Ive had mine for 2 years now and got alot of **** from members on here when i first put it on. "Heat soak"
My only complaint is the weight disadvantage over the plastic type intakes.
Looks real good and i really like that black one, i wonder how it would look in red? It may be a little to much if it was done in red?
Old Oct 29, 2009 | 11:21 AM
SWEET98SS's Avatar
Yeah, the weight really sucked putting it on trying to get it over the oil pressure sensor, I ended up taking the barbed vacuum hose out, then once I got the intake on, I put it back in. I broke my first sensor off because I didnt realize how close it really was back there.
Old Oct 29, 2009 | 12:14 PM
hlaalu's Avatar
good looking intake. they make a polished one too if i recall?
Old Oct 29, 2009 | 12:15 PM
99Bluz28's Avatar
Originally Posted by SWEET98SS
The intake did not sit flat on the heads, I just took a hammer to the coolant lines so they would sit flat on the valley cover. Once you tight the intake down, it should sit flat on the heads.
You did you replace the rear passenger side valley cover bolt with a button head bolt, correct?
Old Oct 29, 2009 | 12:19 PM
SWEET98SS's Avatar
Yep, I did that, my coolant pipes were not sitting flat against the valley covers so I just made sit flat. Actually when you tighten the intake down, it would have probably pulled the intake flat to the heads, I just wanted it to sit flat before I started bolting it down.
Old Oct 29, 2009 | 12:34 PM
99Bluz28's Avatar
Thumbs up
Yeah, I just wanted to make sure before I install my SSI (painted black)and 85mm TB(black), I also want to keep the stock coolant lines.
Thanks!
Old Oct 29, 2009 | 06:49 PM
Monte4ever's Avatar
Where do you get this from and does it use both front and back coolant holes?
Old Oct 29, 2009 | 07:33 PM
'00zbird's Avatar
hey sweet98ss, how's you get the vette style air intake to fit?
Old Oct 29, 2009 | 07:56 PM
SWEET98SS's Avatar
Im not sure what you mean, I just have the lid with the free ram air mod.
Old Oct 29, 2009 | 08:00 PM
'00zbird's Avatar
it looks like something granatelli makes. how you've got the pair of cone-shaped filter there.
Old Oct 29, 2009 | 08:11 PM
  #32
SWEET98SS's Avatar
You talking about Soul TKR's car. That is the voltant air intake. It works with a Ram air hood of some sort.
Old Oct 29, 2009 | 08:21 PM
  #33
hiltsy855's Avatar
Sorry for the newb question - I thought I read that an '02 f-body has an LS6 intake. If so a BBK doesn't gain that much, right?
Old Oct 29, 2009 | 08:30 PM
  #34
SWEET98SS's Avatar
Check the link I put in this thread, bbk is 5 more than the ls6
Old Oct 29, 2009 | 09:08 PM
  #35
'00zbird's Avatar
Does that voltant intake clear a stock sized hood? My scoop is functional. It pipes air around and rams it in on the underside of where the stock filter location is.
Old Oct 29, 2009 | 10:45 PM
  #36
Soul TKR's Avatar
yes it fits on a stock hood. As a matter of fact it was made for a stock hood. I added the thick weatherstripping on mine for additional sealing since I have the WS6.
Old Oct 30, 2009 | 02:26 AM
  #37
M1T/A's Avatar
Looks good
Old Oct 30, 2009 | 03:10 AM
  #38
captainstalin`'s Avatar
anyone else have issues with the screws holding the underpiece on coming undone?
Old Oct 30, 2009 | 06:39 AM
  #39
SWEET98SS's Avatar
Not yet, I wasnt aware there was a problem with this.
Old Oct 30, 2009 | 06:44 AM
  #40
Here ya go
http://www.texas-speed.com/shop/item...id=242&catid=5
