Just Installed BBK Intake
Old Nov 7, 2009 | 12:22 PM
  #61
Nicelysedated's Avatar
Just finished installing mine. Was not fun.......My hands are beat to crap. Broke the oil pressure switch. Bumped it ever so lightly and it snapped. Also broke off 1 fuel injector harness. Wires where kinda brittle after 11 years in the underhood heat. Had to replace all the PCV lines and PCV valve too as they where all rotted. Rock solid idle now (alot of leaks in the old tubing). Gotta wait for the wife to get home to take it for a test spin.
Old Nov 7, 2009 | 06:05 PM
  #62
Soul TKR's Avatar
what supplies do you need exactly to replace all the PCV lines?
Old Nov 7, 2009 | 07:32 PM
  #63
5 feet 3/8 fuel/emissions tubing, brass T, band clamps and some odd pieces of tubing to remake the PCV valve rubber boot.
https://ls1tech.com/forums/generatio...pass-side.html
this pic and thread helped
and the test drive was a sucess, alot of difference above 3000rpm
Old Nov 7, 2009 | 07:42 PM
  #64
FASTEDDIE Z's Avatar
At least it made a noticeable improvement . Good to hear !
Old Nov 12, 2009 | 02:04 AM
  #65
armintheman's Avatar
hey guys i have 2 questions about this intake. i purchased the bbk intake and tb from a guy on the forum and i dont know if it'll work for a 98...i didnt see any addapters that came with the kit nor did i see a special spacer for the 98 cable to strech to the tb. dow anyone know what i should do?
also about the porting has anyone done it to this intake? if so how much gains were there.
Old Nov 12, 2009 | 06:50 AM
  #66
I have a 98 and it bolted right on. Just got to change the aft passenger side engine valley cover bolt with the supplied button head. Also loctite all the bolts on the bottom of the intake, so they dont vibrate out.
Old Mar 7, 2010 | 03:41 AM
  #67
Reno's2fastestfbodys's Avatar
I am about to install a BBk intake is there anything special I need to do?
Old Mar 7, 2010 | 09:48 AM
  #68
garygnu's Avatar
can you can epoxy paint a plastic intake?
Old Mar 10, 2010 | 06:52 PM
  #69
99canadahawk's Avatar
OOO Nice look`n intake`s . I was looking at these & was wondering are they smog legal ??
Just looking at the tube that runs atop/ behind a factory TB do you remove it when installing the BBK or is it still there ?? . .
Old Mar 10, 2010 | 06:54 PM
  #70
SWEET98SS's Avatar
The hole is still there for the egr, it comes with a block off plate too.
Old Mar 10, 2010 | 08:25 PM
  #71
SWEET98SS's Avatar
Heres a pic with my catch can and coil relocation kit. I also polished the valve covers and accumulator for the A/C.
Attached Thumbnails Just Installed BBK Intake-dsc00009.jpg   Just Installed BBK Intake-dsc00008.jpg
Old Mar 11, 2010 | 08:24 PM
  #72
Cool ! I`ll keep it in mind , notice any gain in the seat of the pant`s feel ??
BTW nice Z .
Old Mar 12, 2010 | 11:09 AM
  #73
SWEET98SS's Avatar
I did headers at the same time,seems like the top end defintely pulls more.
Old Mar 12, 2010 | 11:58 AM
  #74
ky_black_ss's Avatar
looks good man
Old Mar 12, 2010 | 12:31 PM
  #75
99Bluz28's Avatar
Were you able to use the factory crossover coolant tubes that go under the intake, or did you have to use the LS6 tubes for the intake to fit?
I had to use the LS6 coolant tubes for my BBK intake to fit, even after replacing the replacing the rear passenger side valley cover bolt with a button head bolt.
Old Mar 12, 2010 | 01:25 PM
  #76
SWEET98SS's Avatar
I used the factory crossover pipes. I just hammered them flat down. Worked for great for me.
Old Mar 12, 2010 | 01:32 PM
  #77
johnlv6's Avatar
That looks good.
Old Mar 12, 2010 | 01:35 PM
  #78
99Bluz28's Avatar
How flat did you hammer them, and did you completely remove all the protective sleeves over the knock sensors wires, did you reroute the wires differently?
Old Mar 12, 2010 | 02:07 PM
  #79
SWEET98SS's Avatar
I didnt hammer the pipes flat but just made them sit on the valley cover flat. I didnt have to remove anything from the sensors. You can though, probably would allow it to sit flatter.
Old Mar 12, 2010 | 02:50 PM
  #80
99Bluz28's Avatar
Thumbs up
Yeah, I guess I needed to flatten them a little more, thanks for the info!
