charging issues....
Old Nov 12, 2009 | 08:35 AM
Havok2's Avatar
Default charging issues....
had some charging issues, went to oreillys, they tested the car with battery/alternator on....seems as regulator maybe was weak so they gave me another alternator, i have lifetime warranty, well, i use the car roughly a week or mor turns on fine and so on, i see the volts about 13 or slightly below.
yesterday, i click unlock on the remote and notice the horn/lights were slow in responding... and now i play with lock/unlock on the remote and notice the horn was weak.
what do you think it cna be it? a weak alternator again? or does it fall into the line of a short? or do i just need more ampage?
any help is appreciated
Old Nov 12, 2009 | 02:34 PM
01'SSLSX's Avatar
sounds like just a Bad battery
Skidog5150's Avatar
Did you have any work done on the car prior to this problem?
Sounds like it could be a short somewhere?
I'd take the battery out and have it tested separately just to make sure it's fine.
Old Nov 16, 2009 | 12:29 PM
Havok2's Avatar
battery was tested, it passed
Old Nov 16, 2009 | 07:15 PM
01'SSLSX's Avatar
when the car is Not running, obvisouly the alternator cant recharge the battery if it isnt Moving.
so, if u'r lights are dim with-out the car running, the battery is weak.
but it could be weak because a light or something is staying on(something is drawing it down) but like i said, it is not an alternator problem if it does it when its not running.
get a new battery or borrow one from a friend (just swap batteries) i bet it fixes it
besides people at O'rielys arent Mechanics (they are just Parts people)
i hope u get it fixed
