Headers or Intake?
Old Dec 12, 2009 | 10:59 PM
Ws6kid.'s Avatar
Headers
:d
Old Dec 12, 2009 | 11:37 PM
edwardzracing's Avatar
Originally Posted by Blk_Ws6
I would build up my engine the way I want it 1st,Then I'll do headers,see what they don't know is headers take away back pressure from a stock engine ,an a stock engine needs back pressure.
Note: Headers are for CAMMED CARS in which more air flow is required.
I'm going to have to disagree with this comment as well. If this theory were indeed correct, my car would have slowed down in the 1/4 when removing the stock exhaust and replacing it with headers.
For the OP's question, add me to the list of guys that would (and in fact did) do headers. Stock with an SLP catback exhaust and 3000 converter, the car ran 14.20's (don't bad mouth, I'm in Utah, high elevation FTL!). After removing the AIR and EGR and replacing the stock exhaust manifolds with Kooks race headers and off road y-pipe, I picked up 5 tenths and ran consistent 13.70's on spinning street tires. 5 tenths is a damn good increase if you ask me.
Old Dec 13, 2009 | 08:33 AM
Blk_Ws6's Avatar
Smile
O yeah! headers are addictive its a must,but look at it like this is pot good for us no, is hanging out in the streets after 12:00 am good no no an no so everything that's good to us is really bad just an example butyou understand.
Forgot to add I read this ls1/ls6 book on our engines and they said midtube headers are better for a stock engine long tubes are for H/C /FI an so on.
Old Dec 13, 2009 | 08:34 AM
Blk_Ws6's Avatar
Edwardzracing That was a real nice pick up .
Old Dec 13, 2009 | 11:55 AM
kicksZ28's Avatar
Thanks for the info guys
Old Dec 13, 2009 | 05:25 PM
fatmat80's Avatar
headers, ls6 intake if u can
Old Dec 14, 2009 | 09:25 AM
Jon@Texas-Speed's Avatar
I would go headers first. We can get you setup with a set of Pacesetter LT headers to get you up and going and maybe save you some cash to put toward your intake down the road. We should have them on the shelf! Let me know if we can help!
Jon
Old Dec 14, 2009 | 10:08 AM
DSkyles's Avatar
I picked up 40 rwhp with headers and an ls6 intake.
Headers first though. Think of it like breathing in and out, and all of the sudden taking in way more air and still only being able to move it out slowly. Same principle.
Old Dec 14, 2009 | 11:21 AM
T AM's Avatar
I went headers first and was very pleased with the results.
Old Dec 14, 2009 | 05:23 PM
kicksZ28's Avatar
i would like a set of pacesetters that are jet hot coated inside and out. I dont know of but one sponsor here that sells them.
Old Dec 14, 2009 | 05:28 PM
Cumbias's Avatar
Exhaust first, then intake. The intake would be choked by the exhaust if done first and would not be that same gains.
Old Dec 14, 2009 | 09:31 PM
  #32
kicksZ28's Avatar
Sent you a pm Jon@Texas-Speed. Thanks
Old Dec 17, 2009 | 10:54 AM
  #33
MonmouthCtyLS7's Avatar
Definately headers 1st.
Old Dec 17, 2009 | 04:47 PM
  #34
VeTTeMaNC486's Avatar
What's with people's car getting quieter with headers? I've owned 3 cars that I have personally swapped the headers on and helped 2 friends swap headers on their car and each one has been MUCH louder than before. On my z06 with borla catback, before the headers I cut the cats out, it got pretty loud, but when I put the ORX and long tubes on, it was on a whole nother level. Same goes for my budy with a lt1 bird, he had a slp LM, we swapped on the headers and it is WAY louder. Rest were on old cars but the same applies.
If you don't want it louder you should look into like a magnaflow catback or something to go along with it because it will get louder, esp. If you get a catless Y pipe. Since you have the lm2 already you should just try it, you might like it.
Old Dec 28, 2009 | 11:23 PM
  #35
kicksZ28's Avatar
Thinking now that when I do headers I will also add the SLP Powerflo addition with my LM2. Hopefully this will quiet it down some with a non catted Y.
Old Dec 29, 2009 | 01:20 AM
  #36
f-bodyguy's Avatar
headers first!....be sure to get o2 extentions!
Old Dec 29, 2009 | 09:39 AM
  #37
ssdeuce74's Avatar
definately headers i'd recomend 1 3/4 primaries if the engine will be mainly stock for a while the 1 7/8 can rob a bit of the torque curve
Old Dec 29, 2009 | 11:04 AM
  #38
DaveX's Avatar
Headers..... in theory they make more sense to me because you should focus on getting the flow out of the motor a little ahead of getting more flow into the motor. And they will give you a little more power compared to just an intake on a stock motor.
Old Dec 29, 2009 | 11:30 AM
  #39
merlinn's Avatar
Headers
