Homemade coil relocation setup?
Old Jun 1, 2010 | 12:03 PM
Mart00SS's Avatar
Originally Posted by Bird-Of-Prey
I used some Taylor 10.5mm wires for a Vette and some 5/16" threaded rod and spacers. This is what I came up with. Sorry about bad pic quality.
Thats pretty slick.
Nice job.
Old Jun 1, 2010 | 01:30 PM
Magnet's Avatar
Well it looks like its pretty cheap to get some all thread rod and a few other things to peice it together.. the problem is the wires are expensive from what I have seen.. Anyone got a hoockup on wires? I want it under my cowl..
Old Jun 17, 2010 | 11:23 PM
01SOMZ28's Avatar
Anyone have anymore pics. I'd like to see some other setups.
Old Aug 22, 2011 | 10:47 PM
Camaro Ken's Avatar
Wheres the wiring to the coils?
Old Aug 23, 2011 | 10:55 AM
Randy WS6's Avatar
I use these to build my plug wire for me coil relocation setup. and got a set of the 8.5 MSD universal wires and cut to fit and installed the LS1 boots and terminals.
http://www.msdignition.com/Products/...s,_2/Card.aspx
http://www.msdignition.com/Products/...ocket/HEI.aspx
Old Aug 23, 2011 | 11:04 AM
Randy WS6's Avatar
I mounted my coils under the cowl, but to do this you will need to shorten the coil wiring harness a bit, The coils are spaced across the valve covers and when you mount them under the cowl the coils will be stacked together and the coil harness will be hanging out every were. The bracket i made is with 1/8" all threads rod and tubing with a 1/8" or larger I.D. cut 1" long to space the coils apart and made a mounting plate out of aluminum and bolted it to the cowl
Old Feb 24, 2012 | 05:02 PM
optiplex's Avatar
heres mine..
http://s1256.photobucket.com/albums/...t=GEDC0915.jpg
http://s1256.photobucket.com/albums/...t=GEDC0907.jpg
http://s1256.photobucket.com/albums/...t=GEDC0906.jpg
Old Feb 25, 2012 | 07:32 AM
Pocket's Avatar
Stock length wires too. Have a SC mounted over the valve cover, so they had to move. If you dont have to move them, Id leave them on the valve cover
Old Feb 25, 2012 | 08:04 AM
hiltsy855's Avatar
Pocket - That's cool. Do you have pics of the other side?
Old Mar 6, 2012 | 10:02 PM
Pocket's Avatar
Its only on one side to clear the blower. Drivers side is stock, but easy to replicate if I wanted to
Old Mar 7, 2012 | 11:18 AM
armyboyatc's Avatar
This is my home made relocation kit. I bought the relocation kit from Thunder Racing that came with the universal 10.5 taylor wires. I used some of their kit and a few other custom pieces I made and it came out like this. It is still a work in progress and isnt fully done but here is what it is so far. I ran the plug wires under the headers to the plugs with the 45 degree angle boots.
I mounted them under the frame just in front of the radiator core support.
I then used some of the plastics from under the car that I deleted to make this box that fits around the coils to protect them from direct water splashes.
And this is what my motor looks like after those ugly coil packs are gone with my GMHTP valve covers.
Old Mar 7, 2012 | 06:40 PM
  #32
CBM's Avatar
CBM
Default Relocation Kit
We have a great kit for under $100.00
http://www.ebay.com/itm/LS1-LS6-coil...#ht_2049wt_933
Thanks
Old Oct 18, 2020 | 06:33 PM
  #33
Purple Poncho's Avatar
I know I'm late to the party here but did the stock hood close without hitting the coils in this spot? Edit: pic from post #19.
Old Oct 18, 2020 | 07:24 PM
  #34
Bird-Of-Prey hasn't been here since 2013
