newb question on thermostat/housing
Old Dec 23, 2009 | 04:12 PM
demonpixel's Avatar
Default newb question on thermostat/housing
Are there different styles of thermostats for LS cars? The reason I ask is because when the thermostat/housing was removed from my LS1, it didn't come out as one piece, it came out in two...
I was under the impression that the thermostat/housing was all one piece. I found this pic and now I'm confused.
Went and got a thermostat for a 98 Camaro Z28 from OReillys and it does NOT fit my water pump housing.
Thanks for any help/advice.
Old Dec 24, 2009 | 01:21 AM
Mumbles's Avatar
You must have a newer water pump on your car with the different style 2 piece thermostat and housing. (They're shown in the bottom left corner of the picture you posted.)
Just return the one you purchased from O-Reilly's and find one from Scoggin Dickey that will fit your application. Thats what I did, when I ran into the same problem with the SLP unit I attempted to install. Here is a link to what you need.
http://sdparts.com/details/scoggin-d...enter/sd105160
Old Dec 24, 2009 | 12:18 PM
demonpixel's Avatar
interesting. thanks for the 411 man
Old Dec 24, 2009 | 12:40 PM
Honda Nick's Avatar
You've got an ls2 style water pump
Old Jan 3, 2012 | 03:15 PM
RedVertTA's Avatar
Old thread but this is relevant to my question. I have a 2000 trans am with the older style water pump. Can I swap the one piece thermostat/housing for the newer style one with the separate housing and thermostat? This would make flushing the coolant a lot easier if I could just remove the thermostat and install the housing without it.
Old Jan 3, 2012 | 03:49 PM
BlumaroZ28's Avatar
Iam not positive but I think the bolt pattern at the housing is different. Easiest way to check would be go to the parts store ask for both parts and compare. If I am wrong some one chime in and let me know.
Old Jan 3, 2012 | 03:52 PM
BlumaroZ28's Avatar
I just double checked that pic you posted and I looks like it migjt work, now I wanna know,lol.
Old Jan 3, 2012 | 04:19 PM
sjsingle1's Avatar
i dont think they swap
Old Jan 3, 2012 | 05:46 PM
RedVertTA's Avatar
Such a shame if they can't swap. Otherwise I could run the newer setup and remove the thermostat to flush the cooling system. That way I get much more flow and wouldn't have to wait for the engine to reach temp.
Old Jan 3, 2012 | 07:10 PM
S10xGN's Avatar
You can take the early style 'stats apart, but it's not as easy as having a two-piece to begin with...
Old Jan 3, 2012 | 07:17 PM
sjsingle1's Avatar
FYI......GM no longer makes LS1 pumps.......has been replaced by LS2 pumps
Old Jan 4, 2012 | 12:42 AM
RedVertTA's Avatar
Is there any advantage or difference in the ls2 pumps other than the newer thermostat and housing?
Old Jan 4, 2012 | 12:57 AM
sjsingle1's Avatar
LS2 pump does not have a bolt that interferes with a fast 102 intake
Old Jan 4, 2012 | 11:27 AM
patSS/00's Avatar
It looks like the newer style should bolt to the older style pump. The older housing has that extra hole, which is just to hold a plastic wire clamp IIRC, which you don't really need. I'm going to replace mine with a new style one the next time I change the fluid, then changing the thermostat will be much easier/cheaper.
Old Jan 4, 2012 | 06:28 PM
FormulaTA327's Avatar
I test fitted a newer style t-sat (2 peice) with the original LS1 style pump, it will not fit right, the end of the t-stat hits the inner rim of the water pump. So you need to match the t-stat with the right pump. Pep boys sells the LS1 style pump which is a Bosch one. And also do not get a new o -ring gasket from advance auto, its to small.
Old Jan 4, 2012 | 07:24 PM
ls1 1990 VN's Avatar
If you use the 04/05 GTO LS2 pump you will not have any problem with fitment or any interference with the fast 102 intake.
How do I know...Cause I've been there & done that.
Old Jan 4, 2012 | 10:25 PM
sjsingle1's Avatar
^^ where did i see that.......hmmmmmmmm
Old Jan 4, 2012 | 11:32 PM
Search is your friend!!
Old Jan 5, 2012 | 02:22 AM
sjsingle1's Avatar
or i could check out post number 13 .........
Old Jan 6, 2012 | 01:14 AM
Nothing to do with any bolt....bolt holes for LS1 & 2 are the same so have no idea what post 13s on about....like I've said search is your friend and you just might find the right thread.
