Need coil wire harness help !
Here's the full (long-assed) thread ahowing anything and everything you'll need to know: https://ls1tech.com/forums/generatio...p-18-6-tq.html
As I recall, the 98's have the coils bolted directly to the valve covers. Is your car like this?
I'm swapping my old LS1 for a new LQ9 w/L92 heads it will have center bolt valve covers.And going to relocate the coils up under the cowl so no need for the brackets .Let me see if I have this right any coil wire harness that was OME for coil acD585 or what I call #5218 will work correct?
The harness is $68 to your door, it is numbered as well, I think it shows in the picture.
The bracket is lighweight aircraft aluminum and the hardware is stainless. (exept the threaded rod)
