Testing testing...ANYONE have back to back w/ LS6 vs LSX yet?
after this thing comes out (and if it pans out that is). The LSX is supposed to have extra material for porting and disassemble to allow for porting.
Out of the box results are not what this intake is about IMO. It may do well out of th box...but it's true potential won't be know until it's port match to specific heads. Heads that flow 315 cfm on the bench and flow 290 thru the LS6 intake, could be able to flow ~310cfm with a port matched LSX thru the intake.
That should be worth a nice gain.
I heard the LSX is worth 18 flywheel hp over the LS6. That's about 14 - 16 rwhp. I have no idea if that was ported or unported.
The real trick with this intake might be to have it ported so some of the older heads that loose 50cfm with the LS6 intake, can flow ~280-290 cfm with the new LSX intake. It would save many the cost of a heads upgrade and that would make a nice market segement for the LSX in additon to the others. IMO.
I think their are way too many folks with LS1 intakes out there and truck intakes out there for the used LS6 intakes to get dirt cheap.
Even if it netted you an additional 15 hp (hypothetically) it still isn't worth 800 dollars.
http://www.ls1.com.au/forum/showthre...5&pagenumber=1
Jay at Absolute was the only one I knew of to "customize" his S2+ heads so they flow better WITH the ls6 intake on. IICR his numbers (direct testing) were about the same as you mentioned.
