Upgrading intake, suggestions?
Old Jan 24, 2010 | 11:23 PM
Eagle02's Avatar
Default Upgrading intake, suggestions?
Hey all-
I'm finally ready to step up from the LS6 intake. This year my setup should look like this:
  • full suspension, LCAs, TA, QA1s, PHB, 9" w/4.11s
  • CNC'd 241s... which kinda sucks, but its a N2O car
  • HSW wet kit setup for 200, -6 feed, large solenoids, purge, FPS, window switch, etc etc
  • Kooks 1 7/8 to 2" stepped headers, planning bullet mufflers of some kind
  • 255 walbro, 42#, wideband perma installed
  • stock cubes, forged pistons and rods
I want to stay with the 200 shot and I'm leaving on it right out of the hole, right around 5k rpm.
Intake wise, I don't think I want to bother with the FAST 90 at all... as its not enough gain over the LS6 to even bother unless its ported big time. I'm also concerned with strength IF the car ever decides to backfire through the intake.
I know the 102 will "work" on the LS1, but through the reworked 241s (that I don't have budget to upgrade this year really) is it really worth all the coin I'll have to drop for a new setup?
What other options are there out there?
Old Jan 24, 2010 | 11:33 PM
smok'nZ's Avatar
MASS seller approved
have you thought about a sheetmetal? or vic jr?
Old Jan 24, 2010 | 11:41 PM
Eagle02's Avatar
Honestly, no. First off, can either of those fit under a stock WS6 hood? I do like the idea of a metal intake tho... simply for backfire protection...
Old Jan 24, 2010 | 11:42 PM
Pwebbz28's Avatar
200 shot? Carb intake all day!
Old Jan 24, 2010 | 11:52 PM
Eagle02's Avatar
Yep, 200. Ran it all last year and the LS6 took it without issue... but it never backfired @ low RPM (it did @ about 4500RPM on my last pass of the season @ 1/2 track... scared the #$%T outta me... but everything was fine less the MAF blowing off and my lid cracking one tab off).
Looking around it looks like Becks or Vic Jr are the main options.
You say "carb intake" which immediately makes me think that I'll be running a carb, but I'm assuming I'd have to run an elbow and put a TB on the front of that... yes?
Old Jan 25, 2010 | 01:24 AM
smok'nZ's Avatar
from what ive read an elbow is a bad ideal alot of people are running top mount tbs 4150-4500's
and yes they both fit under ws6 hood
Old Jan 26, 2010 | 03:00 AM
uphigh07's Avatar
i would run the vic jr its alot cheap and you can use the elbow and just run a plate kit or install it into all 8 runners in the vic jr. if you want to be stealthy about it you can do all the pluming on the bottom side of the vic jr and no one would see your lines under there
Old Jan 26, 2010 | 06:22 AM
garygnu's Avatar
dose fast intakes have a option for a burst panel?
Old Jan 26, 2010 | 06:58 AM
Eagle02's Avatar
The new 102 design is able to be taken apart and have individual top and bottom shells as well as the runners replaced. Haven't seen anything about a burst panel in the newest design.
Old Jan 27, 2010 | 11:12 AM
Eagle02's Avatar
I was educated on burst panels on the 102 yesterday. It's something that you have to cut into the intake and install the correctly sized burst disk to meet your application.
Old Jan 28, 2010 | 12:17 AM
uphigh07's Avatar
yes they can be put on any fast intake, are you not wanting to run a sheetmetal intake? if you run a plastic one if the car backfires through the intake it may blow alot more then the burst panels.
Old Jan 28, 2010 | 12:20 AM
Eagle02's Avatar
You have to deal with heat soak on any metal intake. This car sees about 4000mi / year, so street duty happens. Heat soak would be less than ideal.
Old Jan 28, 2010 | 01:00 AM
ryle's Avatar
Subscribing... In a slightly different boat. I just can't see paying $900 for a piece of plastic... My problem is that my heads are gonna outflow the POS LS6 intake and want to compensate for it.
Old Jan 29, 2010 | 11:09 PM
Eagle02's Avatar
Further research looks like its pointing towards a 102/102 for my application... I haven't heard much from LS1TECH on the subject yet...
