Asp Pulley
Old Dec 22, 2003 | 10:05 PM
artic-z28's Avatar
Default Asp Pulley problems
I dont know if this is a problem or not, but recently my bolt backed out a couple of times.... but now when i tourqed it down to about 140 ftlbs and back the bolt out the pulley comes out with it im like WTF ... so i just reused my old bolt and just drove home becasue i was pissed and tired ..
is this a problem or not ? nothing is stripped .. im just confused
btw i got a new arp bolt im putting in tomorrow and do you think that this pulley could cause slight vibration if its unbalanced .?
thx paul
Old Dec 22, 2003 | 11:02 PM
artic-z28's Avatar
come on someone say something
Old Dec 22, 2003 | 11:22 PM
fastsspr's Avatar
Paul with the new bolt use locktite sealan to secure the treat of the bolt in place.
Old Dec 22, 2003 | 11:32 PM
jrp's Avatar
jrp
SN95 Director
when you first installed the pulley you did use a NEW bolt right? i dont know exactly what i tq'd mine down to but i swear the breaker bar was bout to break i pulled so hard. havent had any problems with mine. you shouldnt have to use locktite as a new bolt should some with some antiseize **** and they are tq to yield.
Old Dec 23, 2003 | 03:11 AM
DaddySS's Avatar
The bolt is torque to yield. If the pulley is now sloppy, then I would be very concerned that you wore down the pulley or the crank or both from it being loose. Put a new bolt in there and have it torqued properly asap before any more damage is done.
Old Dec 23, 2003 | 03:26 AM
Slowhawk's Avatar
LS1Tech Sponsor
If the pulley came off with the bolt,The pulley is NG.When the bolt backed off before,the pulley probly spun on the crank and opened the clearence.
Time for a new pulley..
Also it needs to be torque'd to 240ft/lbs..
Old Dec 23, 2003 | 10:49 AM
artic-z28's Avatar
you think i should put the stock one back on ,,, or could i used the ASP one
Old Dec 24, 2003 | 12:31 AM
artic-z28's Avatar
tttttt
Old Dec 24, 2003 | 12:43 AM
2002SilverWS-6's Avatar
See if the stock pulley is sloppy too. If it starts to go on tight then you should be ok , if not then you got major problems.
Old Dec 24, 2003 | 01:06 AM
artic-z28's Avatar
What do you mean by that, because i tightened it down and it drove home fine no vibrations or nothing ... it just i need to get that ARP bolt in with some locktite
Old Dec 24, 2003 | 02:17 AM
I sent you a pm. Sorry about not understanding you at first. If you use a GM bolt you do not need to use loctite and they only cost a couple of bucks.
Old Dec 24, 2003 | 03:43 PM
Jorday's Avatar
Yah, the pulley's gotta fit tight on the crank or it will come loose.
