Pacesetter header question
Old Feb 2, 2010 | 02:50 PM
ccxxxxxxx's Avatar
Default Pacesetter header question
Will a set of Pacesetter 1 3/4" primary LTs and Y pipe off of a 2000 Formula fit on a 98 Trans Am?
Old Feb 2, 2010 | 03:08 PM
OneMeanZ's Avatar
No, those are two completely different cars.
Old Feb 2, 2010 | 03:21 PM
ccxxxxxxx's Avatar
Is that sarcasm?
Old Feb 2, 2010 | 03:31 PM
J LT1 TA's Avatar
yes it was lol
Old Feb 2, 2010 | 03:42 PM
ccxxxxxxx's Avatar
Cool! I notice that when you buy them online they are 98-99 or 00-02 specific...
Old Feb 3, 2010 | 01:10 PM
Fabian's Avatar
Only time theres any sort of "hang up" is if its an automatic convertible. So I've read...
But what you mentioned should be just fine.
They may be listed the years they are is because 98-00 cars have EGR and AIR. 01 and 02s only have AIR. Or you can delete them both and get the "race version". Depends on how strict your emissions are
Old Feb 3, 2010 | 03:03 PM
MjMaro's Avatar
^ This. The differences in the years are due to the differences in emissions equipment. Although they are listed from 98-99 then from 00-02. My 00 has EGR so maybe someone else will chime in. The "race style" headers will fit any 98-02 with no problem.
Old Feb 3, 2010 | 04:13 PM
brian_rs/ss's Avatar
i have a '00 with deleted EGR/AIR and the exact same headers you speak of. ***** awesome. i got proof in my sig too
Old Feb 4, 2010 | 01:19 PM
BriancWS6's Avatar
Yes, they will bolt up just the same. The difference in them are for emissions hook up.
Old Feb 4, 2010 | 01:56 PM
Redneck Z's Avatar
If you plan on deleting your EGR/AIR, then the 00 header will bolt right up and you won't have any problems. If you plan on keeping your emission stuff, then you will have to modify in order to connect your 98 EGR to the 00 EGR fitting. Alot of people don't understand the difference in exhaust manifolds between the years, so I will try and clarify.
98-99 manifolds are exactly the same and come with EGR/AIR fittings in the exact same location.
00-02 manifolds are the same exact same manifold design, only the 00 manifold comes drilled and tapped for EGR, while the 01-02 does not.
