What are the best headers?
Old Dec 25, 2003 | 10:12 AM
scalemaster's Avatar
Well I'm running SLP lone tube ceramic coated and I'm please with them and they look good
Old Dec 25, 2003 | 12:24 PM
HS-Y2kFormula's Avatar
Originally Posted by TWISTA TA
Dynotech has some new ss headers any y pipe coming out in about 2 weeks........They will also be the only company that uses a ss y pipe, all others are alumnized steel.
Well, that's not exactly true. Stainless Works' y-pipe for their stainless steel LT's is made of T-304 stainless steel. I am real tempted to try them, but am leary of the Catco cats they are planning to use in their y-pipe. I would rather see them use the Magna flow like Kooks or the metallic Random Techs.
Old Dec 25, 2003 | 12:44 PM
wild thing's Avatar
I just got FLP header kit for christmas. It comes with careamic coated headers, coated y-pipe, highflow cats and off road race pipes so you can easily run it without cats. I havent installed the system yet but it looks great. I have pictures in my signature if you go to my webshots page. hope this helps
Old Dec 25, 2003 | 01:17 PM
02CamaroZ28's Avatar
Ive had the FLP's on for about 2500 miles with no trouble. I put them on in July and they fit perfect and tuck up nice. They tuck good and ground clearance is enough with the Sportlines. I went with them because of their reputation/complete kit/ and of course which no other company has....removable cats.
Mark
Old Dec 25, 2003 | 02:22 PM
wild thing's Avatar
Mark
I am about to install this kit with my dad and he has a lift and all the tools and everything because he owns a shop but did you have any problems installing or any tips for people who are about to install them? Thanks alot
Old Dec 25, 2003 | 06:19 PM
Deech's Avatar
PR Director
Mark
Does your y-pipe bang? FLP's had problems with thier y-pipe banging and was wondering if they fixed it. I was looking into these headers or the QTP's.
Old Dec 25, 2003 | 09:25 PM
LS1MONSTER's Avatar
I have SLP lt's and don't have any problems at all. Even being lowered everything is cool. They quality headers and still look brand spanking new from every angle. Very pleased with them. In all I spent 850 for headers install kit and race pipes. Good sale back then. If I were to switch... I would go with QTP, its the cool thing to do these days.
Old Dec 25, 2003 | 09:48 PM
For the two above:
On the install all I had was a floor jack and some jack stands. You can get at all the drivers side header bolts from the top as well as the front 3 on the pass side. To undo the farthest back on the pass side just go up from under the car and its pretty easy. Since you have a lift you will have alot less trouble than I did. The hardest parts were getting enough clearance to get the stock stuff out and enough room for the headers to go in. Just slide the headers in from the bottom. Also for the drivers side the drain plug was getting in the way and needed to be removed. I knew this before hand and did a oil change the same day (plan on this). When you first put the bolts in the drivers side you may think it is really close to the drain plug but once it tightens up there is plenty of room. Any thing else feel free to PM me.
Now to the Y pipe. The drivers side hangs a little low and is the lowest point of my exhaust. There is absolutely no banging under load or on takeoff. Fit is great and glad I went this route. Seems they have fixed the problem.
Mark
Old Dec 27, 2003 | 07:40 PM
Deech's Avatar
PR Director
For the two above:
Mark
Thanks for the info!
Old Dec 27, 2003 | 08:15 PM
1STGEN68-2000SS's Avatar
Flp has to be the best since that is what i just finished installing.
Just Kidding but they slid right in and sound great Iwill let you know hp gain as soon as it gets to the dyno.
Alan
