Gauges flipping out.
Old Dec 24, 2003 | 09:05 PM
Cricket99SS's Avatar
Default Gauges flipping out.
Not exactly sure if this is the right sub-forum for this, but here goes. A week ago this started, whenever I start the car, the tachometer and speedometer peg over as far as they can go. They then both slowly head back to zero. A few seconds after the hit zero all of the gauges come on an go to their normal reading.
This has never happened, and all of a sudden a week ago it started, without any changes to anything. Any experts know what this oddity means? I tried searching around but couldn't find a good way to search for this problem.
Thanks folks, and Merry Christmas!
-Kyle
Old Dec 24, 2003 | 09:43 PM
Ferocity02's Avatar
Ah yes... This is a very common problem with the 99's. Mine does it everytime it starts. I think the fix was to replace the battery, and it's more common when it's cold outside. There is a thread about somewhere, I will see if I can find it. I'm getting a new battery on Friday to hopefully fix it.
Old Dec 24, 2003 | 09:56 PM
Ferocity02's Avatar
Link: https://ls1tech.com/forums/showthrea...ght=cold+start
Old Dec 24, 2003 | 10:02 PM
Hey thanks for the link man. I also found somewhere else where it was talking about a technical service bulletin with the 99 cars, and the gauge cluster had to be replaced. I guess there may be two causes for it?
Would you mind posting back in this thread after you get your new battery, if it indeed fixes the problem? I appreciate it!
Old Dec 24, 2003 | 10:07 PM
Ferocity02's Avatar
Sure thing. I'm pretty sure it's the battery. Ever since it died and I had to recharge it, it has reset the gauge cluster on every start-up. The little green dot on the battery is missing also. I could be wrong though. I will let you know what happens
Old Dec 25, 2003 | 11:39 AM
mcflyz28's Avatar
There is/was a TSB on the gauge clusters new battery solved my problem
Old Dec 25, 2003 | 06:17 PM
Danny2tek's Avatar
yep when I replaced my battery it solved the problem
Old Dec 25, 2003 | 07:06 PM
GrapeApe's Avatar
yah my car does the same and it also is a 99 freeky shizit
Old Dec 25, 2003 | 09:41 PM
Jorday's Avatar
I've seen my tachometer not work. It just sits at 0. It did this 3 or 4 startups one day and that's it. I never saw it do it before that and have never seen it do it since. This was probably 4 months ago. It broke then fixed itself.
