LS6 install/air deleate help ASAP! Please.
Old Feb 14, 2010 | 11:55 AM
1gt2nv's Avatar
Default LS6 install/air deleate help ASAP! Please.
I'm in the middle of putting the LS6 intake in. I removed the air and egr. On the back of the intake, there is a big hose(from the brake booster) and a little small hose. Should I hook the small hose back up or just plug the hole on the back of the intake? I thought I read something about doing that when you remove the air. Any help would be great. I want to put the car back together.
Old Feb 14, 2010 | 02:39 PM
RA032926's Avatar
that small hose is for your ac controls i believe
Old Feb 14, 2010 | 02:44 PM
Squirts11's Avatar
Plug it back in.
Old Feb 14, 2010 | 02:50 PM
99bluehawk's Avatar
Is there a diagram to show where to plug the little hose?
Old Feb 14, 2010 | 02:59 PM
1gt2nv's Avatar
I just put it back on. Have to wait for my pcm to get back from Frost. I checked over the install and everything looks good so far. I did break the opsu. Napa had a new one though. Not a big deal.
Old Feb 14, 2010 | 03:57 PM
MjMaro's Avatar
Weclome to the club lol
Old Feb 14, 2010 | 05:03 PM
DCC!!'s Avatar
yeah i wonder if anyone has not brokin the opsu the first time the took the intake off?? haha
Old Feb 14, 2010 | 05:21 PM
RA032926's Avatar
i didn't ... it's pretty easy to avoid if you're careful... i'm a pretty small dude so i could get my hand in there to guide the brake booster hose over the top of the sending unit
Old Feb 14, 2010 | 05:41 PM
noboundreez2345's Avatar
I snapped the opsu and had to wait a few days for a new one which sucked. Ported tb/ ls6 manifold was a nice knuckle cutting mod enjoy the results.
Old Feb 14, 2010 | 06:03 PM
DCC!!'s Avatar
lucky! i didnt even kno what it was when i broke it lol
Old Feb 14, 2010 | 07:01 PM
1gt2nv's Avatar
I put the big hose( vac line that goes to the brake booster) in front of the opsu this time. So if I ever have to remove the intake, the opsu won't brake. How tight do you make the intake bolts? I tightened them by hand. I just made sure they were nice and tight. Don't want a vac leak.
Old Feb 14, 2010 | 09:21 PM
RA032926's Avatar
lol well knowing what and where it is does help avoid breaking it... i did alot of research on this site before i did my intake swap so i knew what to expect... you don't have to tighten the bolts very tight... i used a small 1/4" ratchet on mine and snugged them up but they aren't too tight... if you have worked on cars a bit then you will know when to stop... if you go too far you could crack the intake or stretch the bolts... i'm sure someone will tell you to torque them to "x" ft lbs but who the hell really uses a torque wrench on something like that?... personally, the only thing i torque to spec are engine/trans internals
Old Feb 14, 2010 | 10:05 PM
Mart00SS's Avatar
One more here that did NOT break the oil pressure sending unit.
http://www.ls1howto.com/index.php?article=5
Check that out, its got good info.
Old Feb 15, 2010 | 05:44 AM
1gt2nv's Avatar
I used a small ratchet also. Just tightened them down pretty good. Do you think I may have over tightened them? Could that cause a vac leak? Sure hope not. I didn't hear the intake crack. There are not crazy tight, but tight enough. Hard to explain.
Old Feb 15, 2010 | 06:49 PM
heartless_T/A99's Avatar
while installing mine i was busy doing something else and my cousin over tightened the last bolt on the driver side and it broke inside the head
Old Feb 15, 2010 | 07:12 PM
Double_Trouble99's Avatar
i just swapped my intake for the first time in a f body and from the countless posts ive seen about people busting there sensor i was super carefull lol. never done one with the motor in an f-body before
Old Feb 15, 2010 | 07:13 PM
MjMaro's Avatar
You're fine. The only "too tight" you can get is if you tighten them out of sequence or if you crack the intake.
Old Feb 15, 2010 | 08:55 PM
Squirts11's Avatar
I didn't break the opsu, but....I was in the process of pulling the intake to grab a lifter I dropped during my cam swap. I guess one mistake for another...
Old Feb 15, 2010 | 09:31 PM
Mart00SS's Avatar
its pretty much impossible to get that lifter out the top, I'd say certainly impossible. Gotta pull the oil pan.
Old Feb 15, 2010 | 09:46 PM
Texhotrod593's Avatar
^^^ he is right! there mite be a slight possibility but highly unlikely you will get it from the top. these motors were built on a totally different platform than the old chevy motors. you dont just pull the intake and the lifters are there...the lifters are actually under the head.
and for the record...just "tight enough" or a guess might do but is the wrong way. they have to be tightened in sequence and at a certain inch lb. which i believe is 44in lbs(first pass) 89in lb (2nd pass)if i can remember and dont mistake that for ft lbs.... maybe someone else can chime in. its been about 6 mo since i have worked on an intake. yes you can get them too tight as the threads will acually pull out from the head. we are talking about alumn heads now. good luck guys
