fast 102
Old Feb 16, 2010 | 05:39 PM
regblkss's Avatar
Default fast 102
I want a new fast 102 for my ls1. what fuel rails and style of injectors will i need? the heads are prc 227 like to get 42#inj
Old Feb 17, 2010 | 05:40 PM
regblkss's Avatar
bump!!
Old Feb 17, 2010 | 06:44 PM
bayer-z28's Avatar
What mods are you running that will require that big of an intake?
I've read that LS2 fuel rails will work.
Old Feb 18, 2010 | 12:53 AM
caviness's Avatar
he said ls1
Old Feb 18, 2010 | 03:41 AM
1badblkz's Avatar
ok, so does this mean that an ls1 would need to buy a ls2 fuel rail conversion kit for the 102 fast intake to work?
Old Feb 18, 2010 | 12:37 PM
1badblkz's Avatar
bump, still need an answer.
Old Feb 18, 2010 | 04:59 PM
camcamaro1991's Avatar
Default LS2 Fuel Rail
https://ls1tech.com/forums/generatio...weekend-4.html
see post # 74
I have the intake setting at home i will try to get a copy of the flow sheet and posted it on here.
Trev-
Old Feb 18, 2010 | 05:04 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Correct, they use the LS2 fuel rail with a spacer kit if you want to use LS1 injectors. FAST has a kit coming soon with the rail and spacers, but they are not shipping yet, according to our rep.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 18, 2010 | 06:22 PM
regblkss's Avatar
so if i use ls2 style injectors then i dont need the spacers?
Old Feb 18, 2010 | 06:25 PM
regblkss's Avatar
im changing the whole set up. 227 prc heads and tsunami cam
Old Feb 21, 2010 | 06:11 PM
regblkss's Avatar
bump!!
Old Feb 21, 2010 | 09:52 PM
Post
you'll need.
1. LS2/LS3 OEM Fuel Rail GM part # 12633511
2. LS2 style (length) Fuel injectors, whatever ##LB you require for your fuel needs.
or
3. LS1-LS6 style injectors but will require qty 4, 1/2 inch spacers to correctly mount the LS2 fuel rail to the intake, or run FAST kits ---> oem LS2 style 146021-KIT/ billet style 146032-KIT <---these kits will include the correct parts to run FAST 102mm intake with LS1-LS6 injectors
i attached a fuel option flow chart.
I will be running LS2/LS3 fuel rail and LS2 42lbs injectors @3bar with harness adapters.
