TB coolant bypass question on ls1
https://ls1tech.com/forums/advanced-...-air-temp.html
Did some calculations a while back - the heated T.B. only increased the temp of the air flowing over it by 1/2 a degree.
It seems that the small H.P. gains, if any, are a result of a slight reduction in under-hood temperatures after performing the tb bypass.
^yeah - the effects are small. It seems that the TB casing cools down a little bit when you do the TB bypass, which can theoretically reduce underhood temps slightly.
Again, we are talking about a very small effect here.
did mine, connected the two use the oem clamps blah blah blah... prob didnt do a damn thing but like stated up top two less bull **** *** clamps to tamper with when taking the throttle body off... it may be just me but i hate those ******* clamps... ESPEACIALLY in tight spaces!!! F*CK 'EM!
#33
stop being a ***** and just do it. go buy three feet of 5/16 hose and two new clamps. connect the crossover pipe to the ******* radiator, and be done with it. you'll have extra hose left over but whatever.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![STFU](https://ls1tech.com/forums/images/smilies2/STFU.gif)
#35
1 Post
For instance, if you take a drinking straw and cut a piece off of it about 1/2" long. . . thats about what is going on inside the TB. It passes straight through it. For mine, I pulled off the little pipes, ground out the hole and smoothed it up. Sorry I never took pictures to explain it better, but this portion of the TB is 110% completely useless. It won't cool the engine compartment, and if you noticed a difference in air temp from doing this, you've wasted too much time looking for miniscule factors of engine operation. Like has been said, it makes it 2 steps easier for removing the TB, cleans up a smidge of the engine compartment and teaches you a bit more about the operation of your car. WOW, this dead horse sure is beat.
