Help**Broken bolt**PICS
Old Feb 24, 2010 | 08:27 PM
<>NTX WS6<>'s Avatar
Default Help**Broken bolt**PICS
Not sure if this thread is in the right place but I could use some input from any individuals who have some experience in removing broken or snapped bolts. I've added some pics of the damage. As you may see, I have already tried drilling it and backing it out with a reverse bit but that was a no-go. I have exhausted any means of removing it with the resources I have available in my garage. So any useful input would be appreciated[IMG][/IMG].[IMG][/IMG]
Old Feb 24, 2010 | 08:39 PM
mike13's Avatar
What bolts are they?
Old Feb 24, 2010 | 08:51 PM
cabech984's Avatar
Water pump bolt?
Old Feb 24, 2010 | 09:11 PM
Yes, it's a water pump bolt.
Old Feb 24, 2010 | 09:14 PM
1BADTALS1's Avatar
drill the whole thing out and tap it for a bigger bolt???
Old Feb 24, 2010 | 09:16 PM
1BADTALS1's Avatar
or drill it out all the way and put in a heli-coil...
just a couple idea's
Old Feb 24, 2010 | 10:27 PM
SweetS10V8's Avatar
Your pics are hard to see, but you can typically weld another bolt to it and then simple turn it out.
Old Feb 25, 2010 | 06:42 PM
1BADTALS1's Avatar
so did you get this fixed?
Old Feb 25, 2010 | 10:41 PM
I havent got it fixed yet. Currently trying to locate a tap & die set. figure I will give the helicoil a go but am still stuck at how im gonna get what is left of that bolt out. the initial hole I drilled wasnt centered correctly and so its off to one side leaving the other half still in there. and the bolt is flush with the block so tacking a nut on the end of it is out of the question.
Old Feb 25, 2010 | 10:53 PM
NinetynineSS's Avatar
Where are you located? I can't see the pic, but have a sweet snap on bolt extracter kit, that is broken in well.
Old Feb 26, 2010 | 01:59 PM
Bout 6 min from TMS
Old Feb 26, 2010 | 02:01 PM
cabech984's Avatar
That gasket surface looks pretty mangled!!!! Id get a heli coil kit for the correct bolt size.
Old Feb 26, 2010 | 02:06 PM
Me too, north or south of tms?
Old Feb 26, 2010 | 02:08 PM
deelong4002's Avatar
Did you try heating it at all before you used the extractor? Usually if you heat the outside surface of the piece that is holding the bolt in, you can get them to break free with an extractor. At least that is how i have done it in the past. Its hard to tell from the pics, but it looks like your hole is far enough off center that even if you do get it out, you're going to be tapping and helicoiling anyway, because i'm pretty sure you ate up the threads on one side.
