LS6 Intake
Old Feb 26, 2010 | 05:27 PM
f-body_racer99's Avatar
Default LS6 Intake
I was looking to buy a LS6 intake and my question is whats the difference (if any) between a 02 trans am LS6 intake, 04 gto LS6 intake and the 03 Z06 LS6 intake. If there is a thread about this already i'm sorry for reposting.
Old Feb 26, 2010 | 05:34 PM
TheBlueKnight's Avatar
Shouldn't be any difference.
Old Feb 26, 2010 | 05:36 PM
Nemesis350's Avatar
Well someone can correct me if i'm wrong, but i think the ls6 intakes are pretty much all the same. Most ls6 intakes, from what i've seen, are advertised as ls1/ls6 intakes, or even z06 ls6 intakes. I'd say just make sure you get the right number 12573572, and you're good to go.
Old Feb 26, 2010 | 05:44 PM
01'SSLSX's Avatar
well gto and corvette are drive by wire throttle bodies. so i dont know if those intakes would have provisions for a throttle cable bracket
Old Feb 26, 2010 | 06:54 PM
I thought there might be a difference guess not.Thanks for the information guys.
Old Feb 26, 2010 | 07:01 PM
lavoy's Avatar
let me know if you find any cheap, i cant find any for under 300 bucks and the 8 hp gain at peak just isnt worth 300 bucks to me.
Old Feb 26, 2010 | 09:46 PM
I thought you get more gains then that. that said does the bbk ssi get more gains?
Old Feb 26, 2010 | 10:05 PM
garygnu's Avatar
studderin did some intake ,TB testing ,over at LSX hardcore.alum intakes = heat soak.
 Michael S. Palmer
Old Feb 27, 2010 | 09:11 AM
randy129's Avatar
12561184 is another common one.
From the archives...
LS6 intake manifold (01-02 F-body) = 88894339 (formerly 88890524, 88890523, 12561184)
LS6 intake manifold (from Corvette Z06) = ? (formerly 12573572)
Old Feb 27, 2010 | 10:02 AM
dgcustomz's Avatar
I had a weiand aluminum intake and the only time it would get hot was at idle. When I was driving around I could pull over and put my hand on the intake and it was cool. I don't need the intake to be cool at idle. It's when I am driving that I need it to be. I didn't go check out "LSX hardcore's" link, but I am guessing it was on a dyno and not on the street. Any engine on the dyno produces more heat while just idling. The incoming air when driving cools them down enough to actually gain power. Alot of people just read what people say here and think it's true, even though some of the people giving the information have never used these intakes before. Either way I swapped to a Fast 92/92 becuase the weiand was getting restrictive for my other mods.
Old Feb 27, 2010 | 03:01 PM
Cool i guess i'll go with the BBK SSI.
Old Feb 27, 2010 | 06:33 PM
garygnu's Avatar
google LS6 vs BBK vs Fast,grate write up.
Old Feb 27, 2010 | 07:12 PM
Yeah I saw it already and it was a good write up. thanks for telling me about it saved me from getting a LS6
Old Feb 28, 2010 | 10:27 AM
sl0w's Avatar
Anyone have any recommendations on how to attach the throttle cable bracket if this is the case? I bought an LS6 intake and didn't pay attention to this small detail...
Old Feb 28, 2010 | 10:34 AM
Nemesis350's Avatar
The ls6 i bought came off a zo6. I didn't have ANY issues with the install, you just bolt in the throttle body, bolt on the throttle cable bracket from the old ls1 intake (mine actually came with a new bracket), and taa daa, you're good to go
Old Feb 28, 2010 | 10:40 AM
sl0w's Avatar
I have two empty plastic holes where the throttle cable bracket goes.... how do I bolt that up? I'm mechanically declined.... forgive me.
Old Feb 28, 2010 | 11:11 AM
MonmouthCtyLS7's Avatar
Nothing
