Help with LS6 Intake Install
https://ls1tech.com/forums/generatio...onversion.html
i am looking for a part number for the ls6 intake throttle bracket where it has two cable mounts for the throttle and tv cable for my trans
any help would be great
oh by the way
removing nut inserts or installing them is very easy
a soldering iron in the center hole pushing the nut into the plastic when it heats up
and a small bolt threaded into the nut insert with a small butane torch heating the bolt up and pulling it straight out with pliers works great
i used to do this for a living making pices for ibm and hp
go figure 20 yr old technology
oh by the way
