What all to buy?
just want to clarify that you need the sims for the rear sensors only. seems like common knowledge but after that thread a few weeks ago i guess its not. -gaskets
-(2) o2 sims
-(2) o2 extensions
-headers
-ypipe
am i missing anything? also can i use the stock bolts or should i get arp ones? and what spark plugs should i get? (mods are in sig) if that has anything to do with what kinda plugs i should get. and hte headers i am using will be flp's
as stated by your ealier post you'll need gaskets (can re-use your old ones, or get new metal ones), stock bolts can be reused, o2 extensions for the front, and sims for the rear if you dont want an SES light. the FLP setup requires that o2 bungs be welded on i believe, check up on it.
as far as tools just basic hand tools and sockets (8mm, 10mm, 15mm, ect), jack/jack stands, breaker bar (helpful), sawzal (sp) (also helpful).
