What is this
Old Mar 5, 2010 | 06:11 PM
molsen's Avatar
Default What is this
I bought a 2000 t/a motor out of a wreck. I am putting this in my 1969 Vette. As I was taking apart the engine to rebuild it I cam across this item. It has a electrical connector and 2 vacuum ports. 1 goes to the back of the intake It is located on the driver side of the engine back toward the firewall. Do I need it? Any help would be great.
Old Mar 5, 2010 | 07:37 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
It's for the AIR system, emissions stuff
Since you are doing a retro-fit you won't need it
Old Mar 5, 2010 | 08:46 PM
molsen's Avatar
Thanks, I just need to plug off the back of the manifold then I presume?
Old Mar 5, 2010 | 08:58 PM
twelver12's Avatar
evap purge solenoid i believe
Old Mar 5, 2010 | 09:03 PM
dgcustomz's Avatar
You sir are correct^^
You sir are wrong!^^
Old Mar 6, 2010 | 02:04 PM
Z28/2002's Avatar
that is on the right side(looking at the motor from the front) front of the intake
Old Mar 7, 2010 | 12:13 AM
cowboysfan's Avatar
pressure control valve. you dont need it if you can delete it from computor unless you are not using factory ECM..
Old Mar 7, 2010 | 12:36 AM
DCC!!'s Avatar
delete!!!!
im pretty sure a ls1 69 vette dont need AIR! or any emmissons for that
