shorty header question???
Old Dec 30, 2003 | 05:04 PM
ba96ta's Avatar
Default shorty header question???
I am looking at purchasing some 98-00 shorty headers and offroad y-pipe for a 02 Z28.
My question is, I want to be able to switch back to my stock y-pipe with cats for emission. Will my stock 2002 cats and y-pipe bolt up to 98-00 shorty headers? Also how hard would it be to get the EGR to connect to the 98-00 style. Thanks for any help
Joe
Old Dec 30, 2003 | 08:49 PM
ApacheDrill's Avatar
The shorties are made to hook up to a stock exhaust easily. They will work fine with EGR if they have the Air tube and EGR ports on the headers. Way back a long time ago.. I had edelbrock shorties. They work fine i had no problems with emisions. Hope that helps
Old Dec 31, 2003 | 08:52 AM
WILWAXU's Avatar
98-99 and 00-02 have different y-pipe setups.
You need a matching set. I don't recommend wasting your time with shorties. Is there some reason you can't go with long tubes?
Old Dec 31, 2003 | 09:07 AM
jrp's Avatar
jrp
SN95 Director
save the money you plan for shorties and put it toward some other mods. the hp/$ ratio for shorties makes them pretty much worthless. also considering you have an 02 which have better flowing stock manifolds then the 98-00.
Old Dec 31, 2003 | 09:18 AM
I also agree with that. I have had shorties , MAC mids, and now Long Tubes.. I kinda graduated to the Long Tubes. I dont have emmisions where i am, but i do know the restrictions in some places and with your concern for EGR etc, i am assuming thats why you are wanting to go with shorties..
Old Dec 31, 2003 | 09:51 AM
jrp's Avatar
jrp
SN95 Director
the 98-99 manifolds/headers also have the air tubes in a different position then the 00-02's.
Old Dec 31, 2003 | 11:52 AM
TaTommyWS6's Avatar
I'm sure he wants shorties due to emmissions. (He is concerned with putting back the stock y-pipe).
That said, he should spend money elsewhere; pulleys, etc...
Tommy
Old Jan 4, 2004 | 01:56 AM
lsx24's Avatar
If you think shorties have no tangable gains you do not know what you are talking about.
 Michael S. Palmer
Old Jan 4, 2004 | 08:19 AM
silverTA's Avatar
my friend's 02 gain 9rwhp from shorty and slp y pipe
Old Jan 4, 2004 | 05:02 PM
lsx24's Avatar
More specifically, a modded car will gain a lot more than a stock car, I agree. On a stock car, a ls6 intake, TB, shorties, or even tuning do not yeild much result. However take these same mods, and add heads/cam/tuning/True Duals, and you're looking at some serious gains. As much as long tubes? Absolutely not. More than stock manifolds? By a lot. There are many H/C cars that pass smog with Shorties (not even true duals) and a med cam, that are putting down 375-390 rwhp. I don't believe you can come close to that with stock manifolds, FWIW in a SMOG legal ride.
Old Jan 5, 2004 | 08:04 AM
jimmyblue's Avatar
Moderator
You might pick up almost as much gain, on an
'02, by simply porting the stock manifolds. The
casting intrudes quite a bit into the port with a
sharp lip and there is flow/pressure to be had,
there.
http://community.webshots.com/album/62991112mIZazn
