LS1 to LS6 Intake Conversion guru's inside!
All your other questions have been answered above.
Oh yeah, did you put the gaskets on the new manifold?
-The intake manifold bolts are a very low tq spec, they are easy to snap if you go nuts on them.
-You need to swap the intake but you have to remove the stock coolant x-over x-pipe. You'll put plugs in the back two holes and the front pipe that just loops the front two holes.
-I usually undo the rear bolts and hold them up with tape (tape around the threads) since you can't remove the four rearmost bolts they are under the cowl.
-This is an easy swap just take your time and don't break anything
-To that other guy sounds like you have a vacuum leak, check your ltrims on atap.
www.ls1howto.com
follow the instructions, and then quit yer bitchin
The swap is very easy.
chris
I'd say be prepared for minimal gains till those noose port heads get hoged out
