3" ypipe to 4" merge
Old Mar 14, 2010 | 08:14 PM
01Blk*SS*'s Avatar
Default 3" ypipe to 4" merge
Anyone have 3" ypipe merged to a 4"ipipe over the axle to a muffler? If so, can you please post pics/reviews? Im going to do this pretty soon and want to get an idea on the best setup for clearance/ sound.
thanks!
Old Mar 14, 2010 | 09:48 PM
STREET99's Avatar
I am doing a similar setup w/o the merge. Mine is just LT Headers into 3inch ORY into a I-pipe into a 3inch Dynomax Bullet Muffler w/ Turndown.
Old Mar 14, 2010 | 10:08 PM
01Blk*SS*'s Avatar
does anyone know the disadvantages/advantages of the 3" y to 4" merge before the I pipe?
Old Mar 15, 2010 | 12:04 AM
-98-Z28-Darkness-'s Avatar
my tsp ypipe looks like it ends in a 3 1/2'' merge( not 100% sure) then goes down to 3'' inlet. looks like all you have to do is chop the piece that minimizes the pipe. plus its a great merge!...i think othe then that you will need to get it custom made ypipe to fit a muflex 4inch catback.
Old Mar 16, 2010 | 12:33 PM
brian_rs/ss's Avatar
pretty soon here i am goin to be taking my TSP o/r y and doing the flowmaster 3"/4" merge with a 4" i-pipe run as far back as possible into a 3" spintech cat back. i haven't really found too much on the 3" spintech but it looks pretty legit, all 3" piping and has a real deep tone. so hopefully this will kill the rasp, fingers crossed.
Old Mar 16, 2010 | 12:40 PM
Z28_LT1's Avatar
why do you want a 4" anyway?
Old Mar 16, 2010 | 01:22 PM
https://ls1tech.com/forums/generatio...heads-cam.html
read post #9
i would love to go with the mufflex 4" cat back but damn they are expensive
Old Mar 16, 2010 | 01:53 PM
01Blk*SS*'s Avatar
What Im gonna do is get a flowmaster 4" merge and a magnaflow muffler with singe 4" inlet with dual 3" outlets. To reduce turbulence in your exhaust you want to keep the same cross-sectional area throughout the exhaust system. going from 2 3" pipes into a single 4" pipe will reduce the turbulence.
Old Mar 16, 2010 | 02:12 PM
turbulence=rasp?
i know for sure turbulence is bad for flow, is it also bad for sound? because i know my TD's sounded AMAZING, and i'm sure they couldn't have had much turbulence.
Old Mar 16, 2010 | 02:18 PM
Twotonefreak's Avatar
I run a 3" mandrel bent Y with a 3" Flowmaster merge that is 4" outlet and necked down to a 3" I pipe, 3" electric cut out. 3" over axle into a Magnaflow muffler and 3" mandrel tailpipes. I pick up right at 10 with the cut out open.
Old Mar 16, 2010 | 02:22 PM
u pick up 10hp with the cut out open? see thats why i really want a mufflex 4" cat back. i dont want a cut out, and i want to be able to get as much flow as possible out of a cat back. i guess i'll be saving up.
Old Mar 16, 2010 | 02:29 PM
blue99fbody's Avatar
when my builds done im gonna be cutting my old tsp y pipe and putting in a 3" to 4" flowmaster merge into a dynatech 4" race muffler and 4" turn down before the axle. i wont know how it will fit till i get the motor back in but i know its gonna be tight bc my car sits pretty damn low.
Old Mar 16, 2010 | 02:34 PM
^ a tip for the turndown, take a grinder and shave off the bottom edge of turndown. that way if you scrape it wont bend up/smash that part of the pipe. i ran into that problem with the turn downs on my TD's. but a big set of pliers and grinder fixed it.
Old Mar 16, 2010 | 02:47 PM
1969mach1's Avatar
read post #9
this looks like Pat's merge.
a Dr. Gas Exhaust.
http://drgas.mybisi.com/products/street-performance
Old Mar 16, 2010 | 03:02 PM
Honestly, I bet you'd still pick up 10 with a cut out, even with the Mufflex system. I've installed a few, they aren't any better flowing than a magnaflow IMO.
Old Mar 16, 2010 | 04:23 PM
not that i doubt your experience, but a 4" cb > 3" cb. it has to be, just like a 4" merge > 3" merge. it's the same concept.
^and thats where the problem lies, it's your opinion and not based on actual testing or actual hp/tq/cfm #'s.
now i would love to see a dyno comparison between 3" y-pipe with 3" merge and a 3" cb with 2.5" tails vs. a 3" y-pipe with a 4" merge with a true 3" cb vs. a 3" y-pipe with a 4" inch merge with a 4" cb with 3.5" tails.
Old Mar 16, 2010 | 04:24 PM
01Blk*SS*'s Avatar
turbulence=rasp?
I would say turbulence is higher pitched at faster velocity (speed). So it would depend on what sound you prefer, deep or high. I currently have tsp true duals on my car and would say its a little raspy. Just think of the true duals xpipe merge and a y pipe merge. the flow in the TD's stays parallel and the streamlines of the flow do not collide at as big of an angle as the ypipe streamlines.
Old Mar 16, 2010 | 04:34 PM
01Blk*SS*'s Avatar
I agree with you Brian, you basically want to get the exhaust out as fast as possible without too much resistance.
Old Mar 16, 2010 | 04:37 PM
yeah i would say my TD's were pretty deep until you hit the higher rpm's and it would be a little raspy. but NOTHING near as raspy as my TSP exhaust.
Old Mar 16, 2010 | 04:49 PM
FirebirdSS's Avatar
You do not need 4" exhaust. You wont gain anything from it over a well designed 3". Unless you plan on going over 500rwhp. If you look at the recipe 500rwhp, he only last 10hp with a 3 inch exhaust after y-pipe through a muffler. Compared to 4 inch dump after ypipe. You would never notice 10hp.
IMHO Larger pipe sounds like ****.
And sometimes a 4" pipe will flow worse then a 3" pipe. Heat, volume, air speed, turbulence it is all effected.
