solid motor mounts?
Old Jan 1, 2004 | 08:48 PM
2001CamaroGuy's Avatar
Default solid motor mounts?
I have a BMR K-member (the kind that replaces the heavy iron motor mount piece). I have been running Poly motor mounts for the past 8 months and they just don't cut it (keep hitting the exhaust on hard lanches).
1) Where can I get direct replacement solid motor mounts.
2) Does anyone make a solid tranny mount?
3) If I drive from say Pheonix to Vegas, will my hands/butt/etc go to sleep from the vibration or is it not really that bad?
Old Jan 2, 2004 | 11:11 AM
anyone?
Old Jan 2, 2004 | 12:40 PM
DERTY's Avatar
The Bull
Spohn makes a very nice set of direct fit solid motor mounts. They are a lot more durable then the ones that you can get elsewhere. Moroso makes a solid transmount, but to be honest the poly ones work fine. I have this setup in my car and it rumbles a bit, but it's not too bad. Just depends on what your tolerance is for it.
Old Jan 2, 2004 | 03:09 PM
B-MAN's Avatar
Spohn has nice ones Ithink they only come in red
Old Jan 2, 2004 | 04:03 PM
err..but those are made to replace the entire motor mount. I need ones that will just replace the "rubber part". My K-member has the integral motor mount.
Old Jan 2, 2004 | 04:16 PM
menikmati's Avatar
DO NOT RUN A SOLID TRANNY MOUNT!!!
if there is any flex in your chassis what do you think is going to be the first thing to give? i know people that have run them and went through many tranny housings. switched to polly and no problems since.
Old Jan 2, 2004 | 05:35 PM
WILWAXU's Avatar
for a soild mount with a BMR K member you will need to ether modify the k member or have someone machine for a set of solid motor mounts.
Old Jan 2, 2004 | 05:59 PM
WILWAXU's Avatar
BTW.. I would fix the exhaust.. not the rest of the car.
Old Jan 2, 2004 | 09:58 PM
ok....well does anyone make a front and mid plate mount for an LS1?
Old Jan 3, 2004 | 09:38 AM
Camaroholic's Avatar
Madman has motor plates and solid motor mounts.
https://ls1tech.com/forums/drag-racing-tech/19326-ls1-motorplate-design-finished.html
I have the same BMR K-member, poly mounts, and no problems with hitting the exhaust... (1.5x 60's, 6k+ RPM clutch dumps). You might consider tweaking the exhaust...
-Andrew
Old Jan 3, 2004 | 11:38 AM
I had to pull the exhaust super close to the body to get ground clearance.
