How the blue HELL do you get the intake on without breaking the Oil pressure sensor?
I forgot the pre-load factor with the Poly Mounts. I used a Scissor Jack to push the Engine over so I could install the passengers side Bolt. I bolted the Drivers side in, then looked at the pass. side and saw it was 1/4" off. I put the Jack between the Frame Rail and the side of the Block and it worked. I killed the Jack, but it worked..lol
#34
Eh dont listen to these guys man... I feel your pain. I did my manifold a few years ago and ended up breaking two sensors. I found the best method was to do the following:
1) breath
2) count to ten
3) enjoy an herbal supplement
4) try again...
I think that some peoples hoses have just aged differently over time (ie some are stiffer than others) which is where the problem comes from.
1) breath
2) count to ten
4) try again...
#35
1) breath
2) count to ten
4) try again...
1) breath
2) count to ten
4) try again...
#36
i have head for years about people braking the sensor and i still cant figure how people are doing it....i have taking my intake off and swapped it atleast 6 times
#37
Right, because Im sure when you started working on cars you never made any mistakes and knew everything there was to know. GTFO with that bs... everyone has to learn somehow... its part of the hobby
#38
Speak of the devil..... I still have the drivers side to do this weekend and do some clearancing for the egay headers as is it recently starting smacking my k-member really gay. It may suck to do work on these cars sometimes but most of the time its because of inexperience(IE first time doing it)
#39
This thread made me laugh... as far as having to have small limbs.. im 6'4 250 lbs and my arms/hands are not small. I said fu** a lot, got scratched a lot, took some time, but got it done. I found that after your in there for awhile the combo of sweat and grime that builds up on your arms helps slide it in.... lube never hurts you know
