Weird situation
Sorry...not trying to be an *******....I just could not resist. Seriously though....sorry to hear about your problems. From everything else you've described, I honestly think that the PCM is highly suspect.
One other thing....vaccum leaks?? I've seen them do some strange things. Just a thought.
I agree with Cam-pcm is seeming suspect. All other operations seem to be running on par from what I can see on the vid or read from your posts.
I will ask some gear heads around here who are neck deep in vette hybrids, if they've ever run into this kind of problem.
Just a side thought-maybe your maf sensor is faulty??
Hang in there bud, you'll get it!
Very very nice ride btw
Before we jump to the pcm being the problem...
I've checked your two codes to see what they mean and here's what I've come up with;
The codes that you have retrieved are ONLY for a 3.8L ecm out of an 02 transam. They don't show up for any ecm's out of a 5.7L transam/camaro. Are you sure the ecm that was given to you/prorammed was out of a 5.7L vehicle? (I know you said it is a stock tune as well)
Besides that..
DTC-P1514 : Actual MAF & Speed Density is Greater than Expected
DTC-P1518 : Loss of Communication Between PCM & Throttle Actuator Control
Now here's the consensus of the gear heads that I've asked about these codes. Your TPS is probably not gettin the 5 volt reference or ground to it. It seems that its not seeing your throttle move so its unable to reference the computer values so that it can increase the injector pulse.
Take a regular Multimeter and read the ohms at the sensor itself. One wire- 5 volts, one sensor and one ground. Check the the sensor to ground with the key off and you should get some resistance with that. It will sweep with the throttle opening.
Next, check the power to ground with the key on to check for voltage.
Check with your pcm tuner to see what pcm he used for you..start with that then move on to checking the TPS.
Hope that helps a little.
Cam and I are almost sure the pcm is to blame for this strange behavior. I believe its either poorly tuned or a defective unit. Im waiting reply from Jesse @ waitforme about the problem. Hes in Longon, England at the moment tuning a car. Im gonna try a 243 from a truck this week-end tho. It has the blue/green connectors but its supposed to work at least.. thats what I red here. I have a 12200411 pcm that I asked to be programmed for a stock 02 Camaro T56. Of course I had a couple of DTCs deprogrammed from the computer, like the rear o2s, EGR. Now if p1514 and p1518 are V6s only codes, it looks even more suspicious. I know late V6 cars had DBW.
One thing that I feel is strange is; if the engine runs, and I unplug the TPS, nothing happens, no codes, no change in the engine behavior. Just like you said, the pcm is not seeing its signal.
Ill jump in the garage in a couple of mins to re-test the TPS.
Thanks a lot fellow canadians to help me out with this. Ive been depressed this week just thinking about this. lol
Thanks man, youre so very right about that. I dont know if its the "pressure" from my friends and family that saw me working on this thing for the last 5 years... "So? You found it yet?" "Any ideas what it could be?" "Daddy lets go for a ride" Gahhh. heh
I just finished testing the TPS. Everything is there. 5V ref, ground and sensor signal. As I open or close the throttle, the signal goes from .49V to 4.83V and the wire is uncut from the TPS to the PCM with 0.02ohm.
Now, everything points at the pcm. I wish I could find a 12200411 local to try. Ill try a 243 this week-end and see how it goes from there.
As a small note. After going through all my gremlins at start up stage I decided that a tuning suite like HP or efilive etc. is not a nicety but a necessity. You can do so much and verify any electrical circuits with its scan tool. Plus you will always want to tweak the tune a little as you drive it you'll notice some room for improvement here and there and without the tools your stuck.
In your case though there really is no clear cut advantage to either HP or EFI-live they both do the job and do it well. Im not certain about how the cost all works though they have this stuff priced more confusingly than cel phone companies do.
I guess Ill do my homeworks before pulling the trigger. Its a lot of money.
In the meawhile, Ill make a few phone calls tomorrow and try to find a tuner that is local to me.
Dont know enough about that guys problem to even begin to deduce a solution
Runs like crap all around isnt very specific
Pocket, would you lend/sell me that computer? What about reflashing it, where can I have this done?
https://ls1tech.com/forums/conversio...own-way-2.html
