can you reverse coil packs?
Old Apr 15, 2010 | 06:53 PM
awd-rwd racer's Avatar
Default can you reverse coil packs?
if i reverse the coil packs when i put them on the spark plugs, will that mess stuff up? i took my coil packs off the bracket when i relocated them. now the car cranks but wont fire. im thinking i may have them switched.
so if its supposed to be:
1 2 3 4
and i have it
4 3 2 1
would that cause things not to work right?
Old Apr 15, 2010 | 07:07 PM
robsls1's Avatar
Sort of lost. Do you mean the coils it self are not in the right location (meaning coil pack 1 is now coil pack 4 going to piston 4) or you have plug wires going to wrong locations?
If wires going to incorrect pistons then yes it will cause an issue.
Old Apr 15, 2010 | 07:24 PM
sorry i almost confused myself writing it...haha.... here is a pic if it helps
Old Apr 15, 2010 | 07:29 PM
robsls1's Avatar
No you have a issue. Reroute the wiring to correct pistons.
Old Apr 15, 2010 | 07:41 PM
figured...lol...would it start like that and run like ****? or just not start
Old Apr 15, 2010 | 07:45 PM
robsls1's Avatar
may run but run like **** throwing codes left and right but my true guess is it will not start as the piston expecting a spark is not getting it.
